Old 10-23-2004, 09:55 PM
my88dream my88dream is offline
Question whats the diffrence
whats the diffrence between a 350 and a LS1, can you convert a 350 to an LS1 or is there more to it than the block
Old 10-24-2004, 09:27 AM
matt11583 matt11583 is offline
Re: whats the diffrence
iron block vs. aluminum block is a major difference.. basically everything is different thou.. teh ls1 is a far better engine but it cost more and is harder to work on..i dont thnk u cant convert a 350 to a ls1
Old 10-24-2004, 01:21 PM
sbackof's Avatar
sbackof sbackof is offline
Send a message via AIM to sbackof Send a message via Yahoo to sbackof
and LS1 is 346 so.....and there are companies who make iron block LS1. .....its not to bad to work on...and you save about 60 lbs over iron block
1 of a kind 99 Z28 M6
Ohau police dept cop car
2004 SLP Calendar car
http://www.cardomain.com/id/sbackof
Old 10-24-2004, 03:44 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
its kinda like compairing a 350 to an ecotec 4 cylender, the 350 and the LS1 have the same number of interchangeable parts as a chair and the space shuttle. two completely different engines from the oil pan to the air filter. there is nothing the same. you can put an LS1 in place of the 350, but no, you cannot convert a 350 INTO a LS1 like you would convert an LT1 into say an LT4 or something.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 10-24-2004, 06:03 PM
can i build a 350 and get it close to a LS1. I understand it wouldnt be the same but im jsut looking for HP, and keeping the cost reasonable
Old 10-24-2004, 09:16 PM
sbackof's Avatar
348 ci LS1
SPORTSMAN SHORT BLOCK INCLUDES
-Polished& refinished factory LS1 crankshaft
-Billet 6.125” connecting rods
-Diamond Flat top Piston w/2cc reliefs or -8.6cc Boost pistons
-Diamond Pro-select rings
-High performance bearings
-All Gaskets, seals and hardware for short block
-Fully balanced/blueprinted/Finish hone w/torque plate, assembled
$2,799.99
SPORTSMAN LONG BLOCK INCLUDES:
-Custom Comp Cams Roller camshaft, Forced Induction or naturally aspirated
-Comp Cams Lifters
-Felpro Head gasket/bolt set
-Double roller timing chain
-SLP blueprinted oil pump
-RGR, Patriot, MTI, GTP or AFR heads
$5,499.99 w/RGR or Patriot Heads
$5,999.99 w/GTP or MTI heads
CALL for AFR pricing
www.ls1speed.com
engine packages
best prices I've seen and its where im getting my 427 or 383 from
Old 10-25-2004, 10:25 PM
89IROC&RS's Avatar
yeah, you can build either a sbc or a LS1 or an LT1, or hell, even a four banger to whatever power level you want, depending on what kind of money you have to spend.
Old 10-26-2004, 06:53 PM
whats the differance between a long block and a short block
Old 10-26-2004, 08:19 PM
89IROC&RS's Avatar
short block includes
-block
-crank
-connecting rods
-pistons
-cam
-lifters
-timing chain
Long block includes all that plus
-oil pan
-heads
-pushrods
-valvetrain
and in some cases
-intake manifold
-carb
-distributor
-valve covers
Old 10-26-2004, 08:53 PM
Dober89 Dober89 is offline
forget the long/short block get a turn key one
Old 10-26-2004, 10:10 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: Re: whats the diffrence
what about one of those fancy heated chairs. they gotta have something interchangeable part with the space shuttle...
*Better power-to-weight ratio than a C6 corvette*
Old 10-26-2004, 10:51 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
heh heh heh, he said long...
Old 10-27-2004, 09:31 PM
89IROC&RS's Avatar
Re: Re: Re: whats the diffrence
wire
Old 10-31-2004, 08:59 AM
is there anyplace to get a kit to put T tops in a regular RS
Old 10-31-2004, 12:57 PM
89IROC&RS's Avatar
eh.... it can be done, but i would DEFINATELY leave that to a professional body shop with experience in body modifications such as that. and youd probly have to have the top off of a T-top equipped camaro to graft onto your body. its a very complex, and precision job, that i would not do on your own unless you really know what you are doing.
