Go Back   Automotive Forums Car Chat > Nissan > Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza
Old 10-23-2004, 08:24 PM
nismoDave nismoDave is offline
Unhappy Swapping motors need help asap
Please, I need help. No mechanic will tell me if I can swap my 1989' Pulsar NX SE Ca18de motor with a 1988 Pulsar NX Ca16de. What I have is the Ca18de, can it fit in the 88' NX pulsar is the real question. My frame is bent too much, its a write off but I have about $5000 in parts that I don't want to throw away ( I'll never get the value back is what I mean), so I found a cheap 88' NX but ... They are both DOHC. ??? So can my better motor fit into the older model ?
Can I do that ?
Old 11-18-2004, 12:18 AM
miverson332's Avatar
miverson332 miverson332 is offline
Re: Swapping motors need help asap
The biggest issue would be the ECM (and all wiring and sensors). I am 95% sure you would have to swap this as well. The motor fits fine if you look at the Chilton specs (Cubic Inches) for both vehicles. You can get both books at the local library if you don't want to go off what I say.
Old 11-29-2004, 09:20 PM
Liquid_Neon Liquid_Neon is offline
Send a message via AIM to Liquid_Neon
actuly, i beleive the ECU will be fine. The REAL problem with swapping ca18de and the ca16de is that the clutch is a cable in the 1.6L and the 1.8 has a hydrolic clutch system.
in order to bring a ca18 into a '87 you would have to swap the pedal to mate with the new engine.
i think a few connector are differant on the wireing harness too. ca18 has less then the ca16 i beleive.
but other then that you should mostly be all set. the ca18de is basicly a bored (spelling is bad) out ca16 with slightly updated wireing (hence less).
good luck
Old 12-20-2004, 12:47 PM
mrjinx103 mrjinx103 is offline
i am facing a similar problem. i want to swap out my 1.6
ga16 12 valve sohc for the sr20de, but no one will tell me whether its kosher or not.
what do u think?
Old 12-27-2004, 12:29 AM
Broke_as_****'s Avatar
Broke_as_**** Broke_as_**** is offline
As far as the actual fit of the engine in the car or as far as legally? Given the proper amount of creativity and money, any engine can be made to fit any car.
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo
Warning: Objects in mirror aren't as fast as they thought they were.
