Old 10-23-2004, 04:46 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
tranny question, need answer asap
i have an 89 civic. what all do i need to change to make an 88 tranny fit? (5spd) do i need new axels? do i need a new clutch and flywheel??
someone tell me asap!
Old 10-23-2004, 07:15 PM
91civicDXdude's Avatar
Re: tranny question, need answer asap
clutch & flywheel.
Actually, i belive you can use your stock flywheel as long as you have an 88 clutch. It will work, only the clutch wont cover the whole flywheel, i.e. clutch is too small, but it shouldn't cause any problems.
As long as you stick with HF/STD or DX/LX/EX/Si, you wont even have to change axles or hubs, and even then, you can use your old stuff.
Old 10-23-2004, 07:18 PM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
I used an accord clutch disc on my stock si flywheel & pressure plate, works fine. I just got one that had the same specs as my stock disc, cept I got it with 21 splines instead of 20.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 10-23-2004, 07:51 PM
1PhatCX's Avatar
so i can use an 88 disc with my 89 pressure plate and flywheel?!?!?! for sure. ur 10000000% sure on this?
Old 10-23-2004, 08:07 PM
If i were you i would buy a whole clutch kit for an 88, but you can use it with your 89 flywheel
Old 10-23-2004, 08:10 PM
1PhatCX's Avatar
ok, but my 89 pressure plate will work????
the reason i ask is because i have a new pressure plate for my 89 and the flywheel has been done recently in the summer. when i got the tranny tonight the guy gave me a clutch disc in good condition as well as a flywheel and pressure plate all off an 88... the flywheel and pressure plate are glazed tho and he told me to just sand it and it will be fine. i dont wanna do that if i can get away with using my 89 plate
Old 10-23-2004, 08:35 PM
put the 88 clutch up to the 89 pressure plate and if it looks like it lines up, then it will work. I was assuming you didnt have any of the parts.
Old 10-23-2004, 08:38 PM
1PhatCX's Avatar
well i was just thinking.... it the 88 disc is smaller... it should work with the 89 plate which is bigger.... since it will work with the 89 flywheel too
Old 10-23-2004, 09:22 PM
4G4D Store's Avatar
if the 88 plate is smaller than the 89, you can't use it - it'll slip like a bitch. I still say just do what I did - use your 89 flywheel and clutch, go to a parts store, lookup your 89 dx/lx or whatever spec clutch disc, then check the specs on it - thinkness, diameter, then look in the accord section for the same spec disc, but with 21 splines - it's easy - I've been running on mine for over 2 years. Then you don't have to run on a smaller flywheel and stuff.
Old 10-23-2004, 10:53 PM
1PhatCX's Avatar
i cant do that man, i need to have my car to drive, i cant wait another week for my store to order a damn clutch for me
Old 10-23-2004, 11:47 PM
4G4D Store's Avatar
I'd call around and see if any place has them in stock. Cause if you put that 88 stuff in, you'll burn the clutch up with that zc - I did it with my si.
Old 10-24-2004, 12:22 PM
1PhatCX's Avatar
well... too late now, everythings together
Old 10-24-2004, 03:15 PM
GTA's Avatar
GTA GTA is offline
Whee..
88 and 89 clutchs should both be 200mm. the 90-91s are 212mm, so using a 88 clutch on an 89 flywheel will work fine. unless its ever been replaced with a 90-91 flywheel.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 10-24-2004, 05:08 PM
1PhatCX's Avatar
nope, 89 flywheel, everything fit mint!
