Check Engine (ghost) light
95 bird/ 4.6/ 91k miles. The check engine light started comming on about a month or better ago. I have replaced 3 of 4 oxygen sensors. Replaced the pcv valve along with the vaccume tubing that came with it. Taken out and thourghly cleaned the MAF sensor. Code reads bank 1 & bank 2 running lean. I feel as though I am chasing a ghost and am at this point almost ready to trade in on something else. I have replaced the TPS sensor...since every time I start up and give it some gas to get out into traffic at approx 3k rpms.. the car holds as if it has a governor attatched to it.... once it warms up its ok just at the point when I frist start it does this happen. So there I have 2 problems... bank 1 and 2 running lean... and a govenor like feeling when I first start it up and give it gas.... and btw it doesnot have to be in gear to have that govenor feeling to it at 3k It does that even in park or neutral.....Any ideas or help would be appreciated..... thanks
Re: Check Engine (ghost) light
Pull the codes again. See if something else shows up.
It's not how fast you can go, it's how fast you can get there. Proper grammar, it's not just for English teachers. I don't pick on any one person, I treat everyone this way. My only pleasure is tormenting those people who work for me. There are no stupid questions, just a lot of inquisitive idiots. |
Since the first time.. I have pulled codes on this engine like 3 times a week... its the same code.... thanks for the quick reply tho
Ok today I had CEL codes removed and cleared... and yet 3 hours later CEL comes back on ... (surprise) And.... its bank 1 and bank 2 to lean
I have the same problem, i talked to the Auto-Zone guy who did my codes. He happened to be an avid Thunderbird guy. He has a 95 4.6 also and he said he had the same problem to. SOmething gets into the MAF and completly messes it up. You have to replace the MAF. He said that he has replaced his 3 or 4 times. Cleaning it just won't do it. Does your car have drastic power loss above 2000 or 3000 rpm?
1995 Thunderbird LX 4.6 Flowmaster Exhuast Hypertech Chip Converted Civic Tube Cold Air Intake New stock MAF(maybe a larger one later) *Soon to Come* Mustang GT TC Lincoln Mark VIII Drive-shaft PI Heads and 96+ Intake Manifold The Plunderterd, stinkin up the whole place. |
oh you do have the power loss. Yeah replace the MAF it's a $100 part, and should clear up the problem. The guy said that it is a pretty common problem on 94-95 4.6's due to the placement of the MAF.
Well I may guess that is inevitable..... So its off to Advance cause they are cheaper than our AutoZone... thanks guys.. I have and will continue to help out here. many thanks for your replies... as always I will help as I know of things to help out with.....
So heres the low down... I went to Advance and ordered a rebuilt MAF sensor....$66.44 + tax got it this morning .. installed it and.. viola! fulll throttle excelleration... along with new wires,,,, and plugs this birds flying once again.... no more hesitation at 3k when first starting and she runs like a dream... thanks for your quick replies and now I know whats going on when the hesitation comes in... its the good ol MAF.
95 bird 4.6 - 90k miles |
