Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 10-23-2004, 04:17 PM
affandar affandar is offline
Question spark plug issue?
I have a '99 Corolla. Recently I've started hearing sounds from the engine area which sound like the silencer / exhaust is bust. Problem is that if it was bust then i should be hearing these sounds even when I rev the engine when in neutral. But I only hear these sounds when the car is in gear and moving. The car also seems to have lost some of its accelaration.
A friend suggested that it might be a spark plug issue. My question is that what are the symptoms of a bad spark plug and is it easily replaceable?
Thanks
Old 10-23-2004, 06:26 PM
I just replaced the spark plug but the problem remains. I can still hear the 'knocking' sound when i rev the engine while in gear (in motion). Any ideas?
This started happening a couple of weeks ago when I got my car fixed after a burnt up starter and starter wiring. Maybe that has got something to do with this?
Old 11-01-2004, 05:48 PM
Toyota91 Toyota91 is offline
Re: spark plug issue?
I have the same problem, I think it's more the timing belt that needs to be replaced. But then again I could be wrong. The reason I'm saying this is I've replaced pretty much everything on my car but the timing belt and water pump.... so!
Old 11-01-2004, 06:28 PM
93rollaracer's Avatar
93rollaracer 93rollaracer is offline
Send a message via AIM to 93rollaracer
if you're getting an engine knock, then the timing belt is the problem. replace that and you should be good to go.
Proud member of DAMM: Drunks Against Mad Mothers
Originally Posted by vinnym86
Metalheads: 93rolleracer
crazy sons of bitches who get hammered, break shit, and scream. yeah, they're pretty cool. right up to the point when they lynch a black guy.
Old 11-01-2004, 07:12 PM
Re: Re: spark plug issue?
I already had the timing belt replaced.. (its the really big thick belt around the left side of the engine ..right?).. but that did not fix it. I didnt get a tune-up though..only a timing belt replace..do you think that would help?
Old 06-02-2005, 07:09 PM
gb643dp gb643dp is offline
I am getting the same knocking sound. It's only when in motion. I really hear it when I make hard left turns. I thought it was an exhaust leak but no luck there. I was thinking more of the transmission but toyota has a good track record with there transmissions. My timing belt has never been changed and it's up to 90,000 miles. I was going to do it this fall. Did you find out the problem? Thanks.
Old 06-04-2005, 07:39 PM
kuj kuj is offline
That's not the timing belt. That's the "fan" belt or serpentine belt. There is no timing belt on the Corolla but instead has a timing chain, which is a good thing. :-)
If it's a knocking/clicking sound when you're turning, it's the outer CV joints. Can't remember which side is bad...if you turn left, I think it's the right side that's bad and if you turn right, it's the left. Check the CV joint boots and see if they're cracked or torn open. If they are, then it's most likely your outer CV joints have gone bad.
If it's knocking/clicking when not turning but under acceleration, it could be the inner CV joints.
