starts then dies
i can start the car with a gas filled rag by the throttlebody but then the car dies when it run it run ok for 25sc then ace like it run out of fule there is a full tank any help
Re: starts then dies
fuel pump?
![]() 1995 Camaro - Z28 - M6 - Hardtop 2007 GMC Sierra 2500HD SLT Classic -R.I.P. Andy (Hypsi)- |
You've got a kickass nickname.. welcome to the forums
Check for fuel pressure, Your pump is probably gone.. Can you see fuel being injected in the throttlebody?? (im assuming its a tbi)
1991 Camaro Z28 |
you can not see fuel ill go but a new fuel pump in and let you all no thank for the help
its a good idea to change the filter at the same time while your under there if it hasnt been done in awhile..
Also, to prolong the life of your fuel system.. Try to keep at least a quarter tank in the car at all times.. When you run your car on empty, the pump starts picking up sludge from the bottem of the tank.. The extra fuel also helps to keep the pump cool
1991 Camaro Z28 |
ok
i put a new pump in and still no differints but two much in it to give up thank tho
have you checked for power to your injectors??? you can buy noid lights from just about any automotive store, and they plug into the fuel injector harness where the injectors normally do, try to start the car, they should start flashing, or turn on, to show that power is being sent t the injectors, sounds to me like for whatever reason the injectors arent getting a signal to fire.
Chevrolet Camaro - I enjoy beating the hell out of people http://www.automotiveforums.com/vbulletin/showthread.php?t=68052 |
