Go Back   Automotive Forums Car Chat > Chrysler > LHS
Old 10-23-2004, 01:38 AM
creslevi creslevi is offline
Check Engine Light
Can anyone tell me how to reset the check engine soon light on a 94 LHS
Old 10-23-2004, 04:06 AM
LHSDriver01's Avatar
LHSDriver01 LHSDriver01 is offline
If you disconnect the battery for 10-15 minutes it will reset it, but if there is a problem the light will come back on. Check for codes before you reset it. Heres how:
To obtain fault codes using the MIL (Check Engine Light):
1. Cycle ignition key to ON, OFF, ON, OFF, ON within 5 second (do not actually crank engine!!)
2. Count the number of times the MIL on the instrument panel flashes on and off. The number of flashes represents the trouble code. There is a slight pause between the flashes representing the first and second digits of the code. Longer pauses seperate the individual two digit trouble code.
Example: Lamp flashes 4 times, pauses, then flashes 6 more times. This is an indicates a DTC of 46.
3. Lamp will always flash 55 at the end of the test. This signals the end of the test.
a list of codes and what they mean can be found HERE
01' Chrysler LHS -- 1 of 10981 [full sig]
All cars appeal to our practical side, but great cars appeal to our passionate side. -2000 LHS/300M commercial
Old 11-20-2005, 09:40 PM
abookout's Avatar
abookout abookout is offline
Send a message via AIM to abookout Send a message via Yahoo to abookout
Thumbs up Re: Check Engine Light
Will these codes work for a 95 LHS?
Old 11-20-2005, 11:01 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: Re: Check Engine Light
yes
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 11-21-2005, 09:21 AM
abookout's Avatar
Wink Re: Re: Re: Check Engine Light
Originally Posted by theFREAKnasty82
yes
Thank you!
