Old 10-22-2004, 10:07 PM
exman98 exman98 is offline
header, why?
I have been doing some studying on header for some time now, but i cant figure it out
how are the 4-1 better at higher RPM's
and 4-2-1 headers beter at the low and middle level.
Does it have to do with back pressure?
I mean how are they able to do better at diffrent levels.
so you are asking me what should you make? Ummmmm.... well i vote meth lab.....helps out the community and gives people like you a job
I love out driving people.
"what's all those cylinders for anyway"
Old 10-22-2004, 10:10 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: header, why?
yes, it has to do with back pressure. a 4-1 header is more free flowing than a 4-2-1 header. Just like single exhaust is better flowing than dual exhaust.
Hey, I'm not doing to bad for being half drunk hehe
Empty Pockets Racing Member #1
Old 10-22-2004, 10:46 PM
Geeko Geeko is offline
Send a message via ICQ to Geeko
what's the matter, not enough boozahol to go full-bore?
you're always half-assing things
BD (Before Deer): Clean... Very Clean.
AD (After Deer): Nascar Ready.
Go Baby Go.
Old 10-22-2004, 10:48 PM
GScivic7's Avatar
Re: header, why?
hahahahahaha lol...in the process of consuming more beer.
Old 10-22-2004, 10:52 PM
racingnut10's Avatar
racingnut10 racingnut10 is offline
Re: header, why?
There are several factors to consider with a set of new headers. As GScivic7 said, 4 into 1 headers are definitly better for high rpm, and this is true for several reasons on top of reduced backpressure. 1. Typically 4-1 headers are flow more freely than 4-2-1's. 2. 4-1 designs scavenge the combustion chamber more effectively at high rpm because they allow the exhaust charge from each cylinder to carry more of it's enertia down-stream of the exhaust port before it meets to merge with another pipe. 3. Most designs create a momentarily higher vacuum during the gas exchange event (when both the intake and exhaust valves are open at the same time) in the cylinder allowing a more efficient charging of the cylinder with fresh air. 4. 4-1 headers are much easier to pulse tune during R&D (that is if tou are buying headers of a major performance manufacturer!) than 4-2-1's.
It's very important to note that these design advantages of a 4-1 over a 4-2-1 are most effective at high to very high rpm on a naturally aspirated engine that breathes well, like say a modified b18c5. The more of a screamer the engine, the better a 4-1 will work for you. However a low reving engine, like say a d16y8, will only begine to take advantage of a 4-1's attributes when it's running at the top of it's limited rev range, and you wont have the revs to compensate for the power that you might lose on the lower end or mid range.
4-2-1's are good for normal engines, with gains every on the torque curve.
4-1's are good for rev monsters with impressive gains up top, and low gain, maybe even losses at normal rpm's.
Old 10-22-2004, 10:58 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
Re: Re: header, why?
Wow I was just going to say resonance, but you summed it up nicely
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 10-22-2004, 10:59 PM
Re: header, why?
For pressurized engines(supercharged, because turbo exhaust manifolds don't really matter) , don't worry about any of the other stuff I talked about earlier. Look for a header designed to flow maximum volumes. Look for large primaries, secondaries, unrestricted merges, gradual bends and straight pipe wherever possible.
Any more questions?
Old 10-22-2004, 11:07 PM
Re: header, why?
so you guys answered that exactly.
as you said the 4-2-1 hwould be good for the d16y8. that is exactly what i have. so i might notice a little boost with the headers.
my whole plan is to actually start a new exos from the headers back >>>>***
the DC 4-2-1 ceramic 2 peace seem to be what i want. what woud be good to finish it off. I would need somthing high flow (might supercharge it later)
something with a sporty or deeper sound.
NOT A WEED WACKER. i would have to shoot myself.
would an Apexi system be a good match.
Old 10-22-2004, 11:09 PM
GScivic7's Avatar
Re: header, why?
if you are going to super charge it, look for a thermal R&D with 2.5" piping
Old 10-22-2004, 11:11 PM
Re: header, why?
To exman98 check out Powercore's stainless 4-2-1. They did really when in a couple of magazine tests a while back.
Old 10-22-2004, 11:14 PM
Re: header, why?
SC is something i have thought about doing. I wasnt sure the size i needed. I figured it was 2.5"
even if i dont SC my little D16. a new exost will still give me a liitle kick and the sound i am looking for.
Old 10-22-2004, 11:17 PM
Re: header, why?
so is this what i should be looking at
http://www.thermalrd.com/honda.htm
I have a 98 civic EX coupe (D16Y8)
Old 10-22-2004, 11:25 PM
Re: header, why?
Those are definitely good headers. A friend of mine had them. THey sound great, fit well, and free up power.
Old 10-22-2004, 11:28 PM
Re: header, why?
hee hee hee
this sounds promising
Old 10-23-2004, 04:00 AM
GScivic7's Avatar
Re: header, why?
yup, those thermal units are so bad ass
