Old 10-22-2004, 09:43 PM
lckycharm713's Avatar
lckycharm713 lckycharm713 is offline
wiper pissers
only my driver side wipe pisser works and it dont really work that good at all. the pass side dont even try to piss out washer fluid. does anyone know whats wrong and can help me out. thanks
2000 Mustang - just a V6 with lots of good looks
1974 Camaro - 350 4bolt main .30 over, turbo 350 trans w/ shift kit.
1999 F-150 Lariat 4x4 5.4L
"Only babies suck bottles (NOS)"
Old 10-23-2004, 03:28 AM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Your washer nozzle is probably clogged up. Try cleaning it out with a small pin. My moms civic is the same way, every couple of weeks I've gotta clean it out.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 10-23-2004, 08:12 AM
Re: wiper pissers
through the outside right. to get to them is a pain because there not in the hood, in the front dash part right under the window. i think the older mustang are different. ill try to use a pin, see what i can do
Old 10-23-2004, 10:52 AM
andrewespo's Avatar
andrewespo andrewespo is offline
Re: wiper pissers
It's best if you can get them off and clean them. When you clean them when their on, your just pushing whatever clogged them back in, so when you go to use the nozzles the fluid will just push the stuff back to the opening.
1988 Mustang 5.0 5spd/CAI,BBK 65mm TB,BBK underdrive pulleys, Flowmaster catback, E303 cam, headers, mass air conversion, Steeda tri ax shifter, 3.73 gears, Trick Flow street intake, 3g 130 Amp Alt.
