Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 10-22-2004, 09:40 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Detonation on premium?
At what PSI does detonation usually happen on regular 93 pump gass in a car with 8/1 pistons?
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 10-23-2004, 10:36 AM
KC Ron Carter KC Ron Carter is offline
Hmm,
Many other factors to consider.
Timing advance or retard, intercooler, air fuel ratio, and last but not least is carbon buildup.
Normally 6 PSI with out fear and 9 psi with controls.
Later,
Old 10-23-2004, 11:05 AM
-Jayson-'s Avatar
-Jayson- -Jayson- is offline
Re: Detonation on premium?
its all about compression. YOu can have an engine thats NA but has a high compression and if the compression is to high it will detonate on 93 octane. Forced induction increase compression, thats why you need higher octane. So the amount of boost to create detonation is different on each engine. Some engines have a low stock compression while others are high. If the stock compression is high to start with, it prolly wont take much boost to create detonation on 93 octane.
2009 Ninja 650 R
stock for now...
SouthEast Ecotec Enthusiast
Old 10-23-2004, 12:22 PM
Evil Result Evil Result is offline
Send a message via AIM to Evil Result
Of course you have the ME4-12 which has 9-1 compression with 20 psi of boost.
I heard it stated in a video about the car.
I disregard my perceived image in the persuit of knowledge.
Old 10-23-2004, 05:38 PM
Thourun's Avatar
Ahh I know but how high can a VR4 boost with it's 8:1 compression pistons considering fuel supply problems, cooling problems, physical tollerance problems, and hotspots are not issues? I'm just wondering how high one can boost on 8:1 compression withought using higher octaine.
1995 3000GT VR-4
Old 11-18-2004, 06:12 PM
02GrandCaravan 02GrandCaravan is offline
Re: Re: Detonation on premium?
Keeping this in mind - I have 9.5:1 stock compression in my 97 Saturn SL2. I've been running 93 octane gas for 5 tanks fill ups and on the dyno with the Powerdyne BD-600 pushing about 6 psi I had some detonation between 5600 - 6k rpms.
Is my stock compression a factor in this or would this be a "adding more fuel" fix. Here is a dyno chart that includes the A/F. About 55 - 5600 rpms you can see the line starting to creep back up so I'm wondering if it's just fuel:
Old 11-20-2004, 04:00 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Consider engine temperature, timing retard, A/F ratio, intercooler efficiency, and spark plug heat range. Look into timing retard systems, fuel controllers and upgraded intercoolers. Believe it or not, you could benefit more from a larger turbo at a lower psi than you are running now. Theres really no set number. It varies with each car.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 11-24-2004, 01:16 PM
JekylandHyde's Avatar
JekylandHyde JekylandHyde is offline
AF - Advisor
As stated there are way too many factors beyond just octane and boost pressure to know when/where detonation will begin.
A stock turbo MR2 could safely run 15 psi without detonation on 93 oct.
If detonation is a concern, I would highly suggest water injection.
I would never run a boosted car without it again.
Sponsorship: Amateur Motorsports <-- Get the book! - books are now available for shipment
Old 11-28-2004, 10:50 AM
Zgringo Zgringo is offline
As Mr.J&K said, I'd never run a boosted car without water/alky injection.
I'd like to add one more little side note being gas is getting so costly. Ever think of running TOLUENE mixed with gas to raise the octane level?
http://www.easyperformance.com/Octan...rd_Content.htm
http://performanceolds307.tripod.com/id9.html
Albert
