2000 Durango Idle Problems
Hello,
I have a 2000 Dodge Durango that has an idle problem. When I first start the car in the morning it idles at about 2000 rpms for the first 30 seconds, then drops back down which is normal. But then when I am driving down the road and approach the stoplight, the rpms jump up and down, between 1000-1500 rpms for a few seconds before returning to normal. This is very dangerous because the car jumps forward when idling like this, which has me concerned about hitting a car in front of me at a light sometime. Also, I can put the car in park or neutral after driving for a while and the rpms instantly rise to 2000-2500 rpms for a few and then they drop back down. Any ideas? Thanks
A driver drives, but a drag racer lives Mods: NOS Powered NOS 3rd Brake Light Cutout NOS Front Grill Clear Plastic Cutouts Custom Painted Interior 250 Watt Thump! Amplifier 600 Watt Electra Box (Two 10" Subs) Neon Lighting Around Subs Neon Lighting Under Car Flip Flop Trunk Spectre Air Filter Shaved Badges Audiovox 6" LCD Screen Interact 5" LCD Screen EuroDezigns Xenon Lights Dominator R16 Tires Black Ghost Flame Decals Pyramid Door Speakers |
did you find a solution
I am having the same with my r/t as well, did you find a solution?
sounds like a vacuum leak
06 performance white 90 LX Hatch 5.0 swap |
Check The Idle Air Control Valve.is Located At The Rear Of The Throttle Body.
Re: 2000 Durango Idle Problems
I had the same problem and replaced the TPS and it did the trick. It's been running great since.
