Need Help!
ok today i was driving down the roadand my power sliding doors just stop working.... anyone know why the power windows would stop working they come on and off while driving down the road
any ideas!
1994 3000GT VR4 Pearl Yellow 1994 3000GT Base Pearl White ![]() Check out my Cardomain Website!!!http://www.cardomain.com/memberpage/800196 |
If its off again on again, you probably have a loose connection on the motor. You'll need to take the inside door panel off and take a look in there. More then likely you'll see a wire either bare and rubbing on the door frame or not seated well.
Resistance Is Futile (If < 1ohm) |
Re: Need Help!
Is there a guide to taking the door apart? I tried it but there was one thing holding it in place in the middle somewhere that I couldent find! There should be a central how to location on the net that everyone can add to lol.
1995 3000GT VR-4 Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup. Soon:Topline Engineering ground wires. |
Re: Need Help!
Yeah, i took my door off a few times before. Go onto google and type in "Dodge Stealth: Removing door panel"
![]() 1991 Dodge Stealth R/t |
Re: Need Help!
If you are unsure how to remove the door panel go to www.stealth316.com and you'll find it there. I can almost bet you hit the window lock button. Happens all the time. Try it before you go tearing stuff apart.
