Old 10-22-2004, 05:13 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
Angry 91 s10blazer brake problems
im leaking from a brake line but that doesnt bother me as much as the fluid coming out the back of the master cylinder i put a new gasket on because that was shot but i can not get the cap to close wout the gasket going down into the fluid causing more to spill out
Old 10-22-2004, 05:51 PM
Fireplug Fireplug is offline
Re: 91 s10blazer brake problems
A leaking brake line doesnt bother you ????????
Where do you drive so I know to keep my family off of the roads!!!!!!!!!
Old 10-22-2004, 06:49 PM
Mikado14 Mikado14 is offline
Amen!!!!!!!
Old 10-22-2004, 09:43 PM
no what i meant was that i know im gonna get that fixed but i would like to know how to fix that new gasket so its not doin what the old one is doing
Old 10-22-2004, 09:47 PM
Are you talking about the insert in the lid of the master cylinder? OR, when you say "back of the master cylinder" do you mean where it bolts to the booster?
If it the rubber in the lid, unless you have the wrong one, it should snap on. You did push the two diaphragms back into place, didn't you?
Old 10-22-2004, 10:35 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Yip, push the rubber diaphrams sticking out up into the rubber part again.
They will push up until they are flush.
Old 10-23-2004, 03:13 PM
i did that and it still blows back out
Old 10-23-2004, 04:25 PM
Is he talking about the master cylinder lid of the very back of the master where it bolts onto the booster.
The master lid leaking is a common problem on a few years . If its the lid it need a new rubber gasket.
And make sure all 4 corners snap down or it will leak.
Old 10-23-2004, 08:10 PM
BlazerLT's Avatar
AF -Advisor
s10blazerman4x4,
Take a picture of what you are talking about and end this confusion.
Old 10-24-2004, 12:02 AM
ok will do in the morn
Old 10-24-2004, 10:25 AM
ok here is the picture
Old 10-24-2004, 12:03 PM
tom3 tom3 is offline
Sounds like the master cylinder is too full.
Old 10-24-2004, 01:28 PM
but its not its actually only half filled cuz it keeps leakin out the back because the new and the old gasket under the cap kept getting pushed into the fluid which sent it out the back and im not leaking from the line which i said above i found its running down the frame rails and such onto the tranny
Old 10-24-2004, 03:22 PM
Listen carefully here, If the master cylinder is only half full and the rubber gasket is pushing the fluid out the top, what's wrong here?
Read the previous posts. Have you pushed the diaphragm's of the rubber back into place? Is the resevoir still seated into the master cylinder?
Just snapping the lid on will NOT push fluid out unless you are doing it with the diaphragms extended.
Hold on a minute, you said "old and new gasket", you do have only one gasket on the lid, don't you?
Old 10-24-2004, 04:44 PM
BlazerLT's Avatar
AF -Advisor
Push the diaphram back up into the lid.
Underneath the lid it should be flat with nothing sticking down into the front and rear resovoirs.
Take a better picture of what you are talking about instead of that picture which shows us nothing.
