Old 10-22-2004, 04:26 PM
burrow77 burrow77 is offline
replacing cat ?
I have a 96' 1500 2wheel drive truck with the 4.3l v-6 engine.
I need to replace the cat and have never done this before. I
just wanted some advice on how to go about it, maybe some parts
or tools i might need to do the job right.
Old 10-22-2004, 08:42 PM
Mikado14 Mikado14 is offline
Re: replacing cat ?
No harder or no worse than changing a muffler.
Old 11-13-2004, 07:27 PM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
Re: replacing cat ?
Some tools you will need..... 1) a hammer...2) a bigger hammer incase the first one does not work properly lol. unless you have a welder and welding expierence the best way is to but the cat, cut out the old one and install the new with the clamps provided....(have never done one or seen one done so i am guessing about the clamps) Once you have it installed drive it down to a local muffler shop and get them to weld it in for you. Most places will only charge a small ammount to do this.
Old 11-15-2004, 05:17 AM
Cam7 Cam7 is offline
I replaced my cat after a Header upgrade. Had a good enough fit that I didnt have to weld. Clamps will do fine as long as there is no leaks. If you do Weld take off the Neg Battery Cable so you dont fry the computer.
