Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 10-22-2004, 04:24 PM
richlover27 richlover27 is offline
2001 sunfire trouble
i have a 2001 sunfire and i stop to get some gas today,when i tried to start it back up ,it just turn over.when i pour a little gas in the carb it runs for a couple of seconds and then shut back down.i`m thinking its the fuel pump.if so what do you use to disconnect the gas lines.i also check all the fuses
Old 10-23-2004, 03:35 AM
sunfiregirl_96 sunfiregirl_96 is offline
Send a message via MSN to sunfiregirl_96 Send a message via Yahoo to sunfiregirl_96
I'm not really sure about the sunfire, but i had a similar problem when I had my jeep.
It wouldnt take gas, thought it was the fuel sending switch - it wasnt. thought it was the fuel pump - replaced it (had to drop the tank and it was a full tank!) - it wasnt that either. It ended up being a loose ground wire connected to the switch on the tank....it wasnt a fuse either.
if ya wanna do it yourself, its a big job...
otherwise send her in to get fixed.
It's NOT how FAST you can drive her, it's all about the driver knowing HOW to drive her FAST!!
'Fire has been put out... She's gone to that big 'ol junkyard in the sky
Old 10-23-2004, 10:41 AM
hotbug1776's Avatar
hotbug1776 hotbug1776 is offline
Re: 2001 sunfire trouble
Carb? well you know you have air and spark, but no fuel. so concentrate on the fuel system. get a Haynes manual, and do the tests for the fuel pump and injectors. it sounds like the fuel pump may not be working, first check the fuse and then the relay before you dive into a tank removal. like SGF96 said it can be a big job.
Old 10-28-2004, 05:37 AM
sirsmiley sirsmiley is offline
to my knowledge the 2001 has fuel injection..............what is he talking about carbs
