Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 10-22-2004, 04:38 PM
hotrodihc's Avatar
hotrodihc hotrodihc is offline
'99 yukon interior lights stays on!
intermittent problem with interior and running board lights staying on after exiting vehicle and locking doors. Replaced the remote function module but it did not fix. Have made sure all doors are closed and locked of course... turning on the light override prevents problem, but no lights at all obviously.
Any ideas?
Old 11-14-2004, 11:57 PM
lodownlv lodownlv is offline
Send a message via AIM to lodownlv Send a message via Yahoo to lodownlv
Re: '99 yukon interior lights stays on!
the dore swittch located on the insided of the door on the side of the dash board is a negetave trigger and go bad all the time replace both of them for a total of 20 bux.
Old 01-09-2005, 06:29 PM
myhd myhd is offline
Re: Re: '99 yukon interior lights stays on!
I have just purchased 2 new switches. Can someone tell me how to take out the old ones? Will they come out from the front or does the dash have to be taken apart?
Thanks for any help.
Old 01-14-2005, 08:03 AM
they pull right out
Old 01-15-2005, 02:07 AM
99DenaliMan 99DenaliMan is offline
If that doesn't work. I had the same problem. Found out only after I was diagnosed with a bad BCM (crooks, LOL) that my Alarm Sensor was set to high. Fixed the problem for free. If the previous doesn't work simply pull the 4 screws for the middle consoleand remove. (2 screws under cup holder liner, 2 inside area where 6 disk cd changer is located). You will see the sensor if its up to high it will be constantly light. Hope this helps.
Old 01-15-2005, 11:39 AM
Thanks for the suggestions. I tried a new switch on the drivers side and it seems to be working again.
The switch was $8.95 (Canadian) at the local GM dealer.
