Go Back   Automotive Forums Car Chat > Suzuki > XL-7
Old 10-22-2004, 03:06 PM
mjf2004 mjf2004 is offline
Keyless Entry Programming Instructions
Does anyone have these, or know where to get them?
Thanks in advance.
Old 11-05-2004, 09:28 AM
ukpbz ukpbz is offline
Hi,
Did you ever find out how to do this?
If so how ;-)
Thanks
Old 11-05-2004, 09:38 AM
Re: Keyless Entry Programming Instructions
Yes -- found it on another forum. Go to http://forums.vmag.com/suvvit0199/messages/1942.html
Haven't tried it yet, so don't know if it works.
Good luck
Old 11-05-2004, 09:50 AM
Hi,
Thanks for that. Doesn't cover the XL-7 sadly :-(
Paul
Old 01-14-2005, 07:05 PM
mazdatech mazdatech is offline
xl-7 programming instructions first you need to stuff your head up under the dash and locate your module drivers side upper corner under dash does it say programmable transmitter (the first models had no programable modules) if it says that then......
1 confirm all doors are shut and key is out of ignition
2 open drivers door insert key and turn to on within 10 sec
3 turn ignition switch to off in 10 sec
4 push and release drivers door switch 3 times in 20 sec
5 turn ign. switch to on in 10 sec
6 turn ign. switch to off in 10 sec
7 press and hold lock and unlock button on transmitter for 5 sec within 20 sec of step 6 alldoors will lock/unlockto confirm correct process
8 press lock unlock buttons on second remote within 5 sec after step 7 once again all doors will lock/unlock to confirm
9 to add another remote up to a max of four repeat steps 1 through 8 this was taken directly out of an owners manual supplement that comes with a new keyless entry kit (part number for a xl-7 or grand vitara can't remember which one it goes to but it works on either one is 84900-67810) which you would have to purchase if yours is not programable these instructions are the same for vitara, grand vitara, xl-7 and the esteem hope this helps
Old 06-30-2005, 01:58 AM
otoupaliks otoupaliks is offline
Send a message via AIM to otoupaliks Send a message via MSN to otoupaliks
2002 XL7 Remote Program Instructions needed
I saw the programing instructions on this thread and I am wondering if anyone knows about the programing instructions for a 2002 XL7 for the keyless entry? I have read several places that the kind people that created this keyless system in the 2002 made it so you cannot reprogram it and you have to replace the entire keyless entry system. has anybody found this to be true? and if not do you know the reprograming instructions for this unit?
does anyone know what model i need for my 2002? I have one remote but the sticker is torn off the back so i dont know if i need a MOZD02TB or a MOZD01TB remote.
thanks in advance for the help!
Old 11-09-2013, 01:15 PM
autoexpert2 autoexpert2 is offline
Just goggled for you and found .
http://programkeyfob.com/
