Go Back   Automotive Forums Car Chat > Mitsubishi > General Discussion
Old 10-22-2004, 01:43 PM
meganlove meganlove is offline
Question Drifting VS Power Slidng
A few friends and I have been arguing over this matter. They are saying that drifting with a front wheel drive car is power sliding, which isn't really drifting at all. Is there any truth to this?
Old 10-22-2004, 09:33 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: Drifting VS Power Slidng
yes, FWD "drifting" is a contradiction, there's no such thing
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 10-23-2004, 04:14 PM
I knew it! So clarify for me the diference between drifting and power sliding. I know that power sliding is a form of drifting but what diferentiates the two.
Old 10-23-2004, 04:51 PM
drdisque's Avatar
to drift you try to carry as much speed as you can through the corner, therefore you brake less than proper racing line (aka grip racing)
to power slide you actually have to pinch down on the brakes so much that you actually oversteer, if you tried to under or late-brake you would just understeer off the corner, therefore, a powerslide uses more brake than proper racing line.
Dr. Disque -
Current cars:
2011 Mazda2 Touring
Past cars:
Old 10-23-2004, 09:57 PM
You said earlier that there is no such thing as FWD drifting but there is. What you have to do is use your side break lose traction and send your car into a drift, the rest is done the same, take the next corner. When I was in Santa Barbara I actually saw a guy drift a FWD car.
Old 10-25-2004, 12:42 AM
drdisque's Avatar
thats not drifting because it actually lowers your exit speed because you use MORE brake
Dr. Disque -
Current cars:
2011 Mazda2 Touring
Past cars:
Old 10-25-2004, 01:08 AM
ec437's Avatar
ec437 ec437 is offline
powersliding is when you throw the car into an agressive, oversteering line (in which your tires are sliding), and then use the throttle to control how much traction the back wheels have, therefore controling how far they slide out, thereby controling your line through the corner without using the steering wheels except to initiate the powerslide. Powersliding is, by definition, impossible with a FWD car. It is similar to drifting, which can be done artificially in a FWD car using the handbrake. The thing about this handbrake method is that you cannot mantain it for long, whereas in a RWD car you could, with enough skill, theoretically keep the car in a circular drift indefinitely. (until your tires wear out, that is...)
SoStAsSaId: and the flight attendant is cute... if i was a lesbian, i'd join the mile high club
<---call this number
