Old 10-22-2004, 01:02 PM
prankstar prankstar is offline
Need help Flushing Coolant
Hi guys, I need a little help flushing my coolant. I've heard of filling the system and running the engine. Than drain and repeat. But that doesn't exactly sound like a good idea to me. I've also heard of draining the system and putting it all back together, then sticking a hose in the radiator cap and let the engine run. I guess you would keep the drain plug open in this procedure. Could somebody explain the latter procedure to me, because I'm not 100% confident that is correct way to do it. Also what is the best way to drain the engine. Thanks
My truck is a 1994, C1500, 5.7L
Old 10-24-2004, 12:48 AM
Surely somebody can help me out here.
Old 10-24-2004, 09:42 AM
broughy84's Avatar
broughy84 broughy84 is offline
Re: Need help Flushing Coolant
buy some prestone super flush and follow the directions on the bottle. Fill the system, runn for 10 min. drain. fill with tap water, run for 10, drain, and again. Then change the thermostat while you got the rad empty. Fill with proper mix and you will be good to go.
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
