Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 10-22-2004, 09:57 AM
schillbang schillbang is offline
cd player problems
i am trying to install a new cd player in my 98 jeep. it has a infinity sound system with a 6 disc cd changer. i put a new cd player in it and i am getting power to it but no sound. this problem usually means that wires are touching but it is a clean install. i just have no idea what the problem is. when i put the stock cd player back in the sound works...help me
Old 10-22-2004, 10:24 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: cd player problems
sounds like the new deck is bad
Old 10-22-2004, 10:29 AM
Caribbean ZJ Caribbean ZJ is offline
Saw on another forum something like this before. Think it has to do with the antenna wire hooking up to a blue wire from the deck. Do more research i dont think the deck is bad.
Old 10-24-2004, 11:07 AM
the deck is not bad i thought it might be but i put it in my other car and it worked perfect
Old 10-24-2004, 11:33 AM
Myrtle Beach Myrtle Beach is offline
I think carribean is right, It sounds like your amp is not turning on with the new unit-therefore, no sound. The blue wire (from the head unit) is your power antenna/remote wire. This needs to be connected to your amp remote wire (sorry, but i am not sure what color that wire is) If you are using a wiring harness just follow the wiring instruction for the power antenna or remote and connect the blue wire from the head unit to it.
---99 Jeep Grand Cheerokee Limited 4.7 V8 -2" Lift -265X75 BFG---
Old 10-24-2004, 01:48 PM
yea, did u by a SCOTCH wiring harness for the JEep, or did u hard wire it?
Old 10-24-2004, 05:31 PM
kaasa_d kaasa_d is offline
he used a SCHOSCHE wiring harness.
Old 10-24-2004, 05:35 PM
yea SCOSCHE....lol
Ok well go back thru the wiring on the SCHOSCHE harness and the wiring for the new deck , and make sure they right.
I swapped my infinity out fr a pioneer , got the wiring harness and read thru both of the wiring instructions made sure they were hooked up right, and I haven't had a problem.
Old 10-26-2004, 08:44 AM
Try this, Green/Brown wire from car harness connect it to blue wire for power antenna. this should power amp.
Old 10-27-2004, 04:41 PM
Godzilla.vs.Jeep's Avatar
Godzilla.vs.Jeep Godzilla.vs.Jeep is offline
Here's a good piece on the Chrysler/Jeep stereo wiring:
http://www.installdr.com/Harnesses/DCP-Wiring.pdf
Hope that is of some help.
