Old 10-22-2004, 09:13 AM
timetowinarace timetowinarace is offline
Send a message via MSN to timetowinarace
disabling govner?
'96 v6. Can this be done? At 120 mph it shuts itself down. Have another 3 grand on tack that can't be used. I know this is a legal issue with manufacturer but there has to be a way to disable? Any thoughts?
Old 10-22-2004, 01:19 PM
Dober89 Dober89 is offline
Re: disabling govner?
i think it can be disabled through the pcm but you have to hook one of those tuner machines upto it I think.
Old 10-23-2004, 02:18 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
yeah you need a programmer.. Problem is, im not sure if they make one for the V6.. Look at
PCMforless, Hypertech, JetChips.. bout all I can think of for now..
1991 Camaro Z28
Old 10-26-2004, 02:47 PM
BrakeTorque's Avatar
BrakeTorque BrakeTorque is offline
Yea im currently using the latest one the programs called pathfinder and tho expencive i can tune everything intake,stall converter,and the speed limiter.
Old 10-26-2004, 10:05 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
you have to reprogram the ECU, however no one makes one for the pre-98 v-6s. none of the PROM flasher programs that some sites sell dont have the correct files for the sixers. tis the life we chose...
*Better power-to-weight ratio than a C6 corvette*
Old 10-26-2004, 10:21 PM
I just used a programmer on a 1991 LeSaber yesterday i will get the name of the old system for you maybe you might be able to find one.
Old 11-10-2004, 02:46 PM
demon9766 demon9766 is offline
Send a message via Yahoo to demon9766
Buy a programmer and u can chang a lot of things like the shift points and speedlimiter air fule mix and more. th
Old 11-10-2004, 04:46 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
As it stands right now there isn't a program or anything that I know of for our cars (93-97 v6). Shoot me a PM tho this winter cuz there may be one then.
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 11-13-2004, 11:33 AM
Re: Re: disabling govner?
Yes there are a few . Try hypertech,or Granatolli Motor Sport,they have a few units that come with the programmer an the cooler thermostat,that u will need to make it work right.
Old 12-10-2004, 10:35 AM
hellraiser319's Avatar
hellraiser319 hellraiser319 is offline
Registered User
not responsible for the consequences i will state outright. i dont know how well it would work with obd II since this is the old school way that works on third gens. but what you do is disable the vss and then the computer has no way of knowing how fast and no limit. problem is speedo doesnt know how fast ur goin either. you could also wire in a switch to the wire(s) to enable and disable at your pleasure. i dont recommend doing this tho as it is considered tampering with the odometer and its illegal and all that. be responsible if you do bypass the limiter, dont need to lose another f body
Old 12-10-2004, 01:03 PM
SHannonh SHannonh is offline
You are electronically limited. I don't care what anyone says, you cannot bypass this using any programmer. I've been working on Camaros and Trans Ams for almost 6 years now and have yet to see it properly done
Your better off not going that fast anyways unless you have Z rated tires
-Shannon
Old 12-17-2004, 03:59 PM
92rs25th's Avatar
92rs25th 92rs25th is offline
Send a message via MSN to 92rs25th
I ran two lines with gator clips to a bypass switch ( with a cool green light ) just get a wiring diagram of the car , there is always someway you can do it at the harness. Find the wire on the diagram that runs for the Governor , color code it to schematics , snip it , connect it to a switch , turn it off and on at will. Dunno if that would work for a 97 though. I have a 3rdgen and it worked fine.
I love rice so much , I eat it daily. Yum yum Civic.
1992 RS Camaro 383.
2004 Mazda 6.
2003 Subaru Legacy GT Limited.
1984 Nissan 300 ZX
1993 Mazda MX-3 ( Newest addition to my collection. )
http://photobucket.com/albums/y187/ohjiro
