Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 10-22-2004, 06:41 AM
rceyba rceyba is offline
Unhappy Auto-lock/unlock not working
Good day everyone. My '97 Venture will not automatically lock the doors anymore once you shift it into gear. Conversely, it will not automatically unlock the doors once you place it in park and turn the ignition off. Any ideas?
Also, an unrelated question. Most lights on my radio have burned out. How do I replace these?
Thank you,
Rick
Old 10-22-2004, 08:10 PM
GregA's Avatar
GregA GregA is offline
Re: Auto-lock/unlock not working
Rick,
Do the locks still work when using the Remote or buttons on the door(s)?
Also check you Backup Lights (and fuse). Repair manual shows that the transaxle range switch (shifter) gets its power through that circuit/fuse. Owners manual says it is fuse # 27 in the engine compartment (this is a 2001 manual).
Take care,
Greg A.
Old 10-23-2004, 01:33 PM
broughy84's Avatar
broughy84 broughy84 is offline
yeah how do you change the lights on the radio...all of mine are blown out.
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 10-25-2004, 05:59 AM
Thanks to Greg A. for the suggestions. I found out that the solution is just a simple program setting. According to the manual, you can change the settings of locks, interior lights, etc by making a couple adjustments on your own. There is a fuse that you must pull from the passenger fuse panel. (something like 'BCM PRGRM') Then ,turn the key to the accessory position. Then, hit the lock button on the door until you hear three chimes. return the fuse & it is all set.
Old 10-25-2004, 10:09 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
I own two 97 Ventures , and one of them has this problem. I've had to reprogram it a few times the way rceyba mentions. Don't know why it only happens to one of the vans and not the other, and why it happens every so often.
