Old 10-22-2004, 06:26 AM
Przemir4g Przemir4g is offline
Check Eng
in my ECU i have Check Eng - I can see nr 23 but I dont know what it`s meen - plss help
car civic b16a1 - obd0
Old 10-23-2004, 01:48 AM
1990civicdxhb's Avatar
1990civicdxhb 1990civicdxhb is offline
Re: Check Eng
whats nr 23?
Also,just to give you some info,if your check engine light is on,
pull your carpet up from the passenger side,under the dash,
thats where your ECU is,
you will see a clear circle,start your car,it should flash once when the car is started,if it blinks any more,then theirs probably somthing wroung,
write back how many times it flashes(if you dont know what the code means),it pauses when the code ends & flashes a new code or repeats the same one,
let us know how things work out...
In the process of B00stin my D
Old 10-23-2004, 07:02 AM
Re: Check Eng
woow man !!!!!!!!!!
I know how to do IT !! and I have nr 23 !!
and now I know what my problem is !!
if someone is curios PM me
Old 10-23-2004, 02:03 PM
Re: Re: Check Eng
sorry bout that...
I just looked over & seen you was a newb & you was talking about the ecu,
done the 1st thing that came to my mind!
