Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-22-2004, 02:47 AM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Question Q Octane
Just curious... there is a gas station nearby with 110 race gas... um what might be the chance that I could use it? Would mixing 1/2 race with 1/2 93oct. give me 101.5 octane? lol I've always wondered if that works that way..... Thanks lol
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 10-22-2004, 07:55 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Q Octane
As long as it's unleaded you will be fine. You can run leaded gas, but I think it kills your cat and o2 after awhile.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 10-22-2004, 12:46 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Q Octane
IF you have at least 1000 miles on your O2 it will sirvive fine with leaded gas. I run a few gallons a week through the car for years. If you run it on a new sensor it reportedly wont last the night though. I never bothered to test that theory, too expensive But other locals have. The cat though is another story. I started get cat CELs after a couple months of weekly leaded fuel usage.
You are correct in averaging the two fuels. You can do the same thing with odd proportions too. Like 8 gallons 93 and 2 gallons 110 would be 96.4, etc.
The way I run this stuff is to empty the tank first. I put a 6 foot 1/4" fuel line on the fuel pressure regulator output and stick it in a jug. Then run the car (or kick the pump on in DSMlink) until the pump has emptied the tank into the jug. Anything less than a quarter tank on my car will fit in a 5 gallon jug. THEN add the race fuel, 5 gallons. I run 117 octane, at 8 something a gallon, so this first fill up is expensive When racing is over and its time to go home, I use the same procedure to pump out the race gas into a second jug. Then add in the pump gas I pulled out. I usually get 3-4 gallons back out of the car, so the next week I only have to buy a gallon or two of the expensive race fuel.
This will get you your moneys worth, and limit the amount of leaded fuel the O2/cat have to deal with. The example above with 8/2 gallons would be running lead through the motor for a couple hundred miles. If you are just going to try it out or dyno for the day, etc, just run the tank to the E mark and add ~2-3 gallons. Dont fill up again until you run it down to E again. On the dyno you can run the tank pretty low. If you are going to be driving the car, try not to go below 1/8th tank, since the fuel may slosh around and allow the pump to pick up air.
Not sure why I just went through all that, I cant even remember wtf the question was. Oh well, enjoy...
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-23-2004, 09:46 AM
Re: Q Octane
LOL... thanks kevin!! i'll have to give it a try sometime...I'm not sure but I think it is unleaded 110 oct. If there is lead in it then it would go just fine with my paintchips!!! lmfao
As for the O2/cat... I have high flow cat and 2nd O2 already gave me a CEL...reset codes and it comes back after 40-50 miles......
Old 10-23-2004, 10:08 AM
AF - Advisor
Re: Q Octane
I probably wouldnt worry about it being leaded then. I dont think I've ever seen 110 unleaded, and unleaded up to the low 100s (like 104) is almost as expensive as the leaded 117 If its a sunoco station, its most likely CAM2, a very popular 110 octane leaded race fuel. A handful of local stations here sell it as well.
Kevin Jewer
Old 10-23-2004, 03:34 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: Q Octane
fucking california... i'm still searching for the 1 station that i have heard has 104 unleaded...
Old 10-23-2004, 06:42 PM
george536's Avatar
george536 george536 is offline
Re: Re: Q Octane
the highest ive seen in cali is 100. man california needs to lighten up on emissions.
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 10-23-2004, 09:28 PM
AF - Advisor
Re: Q Octane
Any drag strip should sell the good stuff. If you find it at the pump anywhere consider yourself lucky. And the nozzle is too big to fit the car anyway, you have to put it in a jug (emissions law). Race tracks have drums of the shit in a dozen different octane ratings.
Kevin Jewer
Old 10-26-2004, 05:09 PM
Re: Q Octane
there is a unicorn station around here that i have heard myths and legends about for a while now. i haven't looked high and low, so i may find it soon...
Old 10-26-2004, 07:59 PM
metalhedskater's Avatar
metalhedskater metalhedskater is offline
Send a message via AIM to metalhedskater
Re: Q Octane
cant there be dangers putting in 100 octane unleaded fuel in your car if your just driving it around the streets, instead of the track? Could it mess up your car?
99 GST/evo 3 16g/3" Catback/Intake w/filter/UICP/1g BOV/Complete prothane motor mount inserts/Boost gauge/AF ratio gauge/MBC/NGK Plugs/HotWires/17" Sport edition fox 5 racing rims w/Fuzion tires
One retarded ass site! Geeeeeeeee
My Car
[url=http://www.myspace.com/nobledsm[/URL]
Old 10-26-2004, 09:45 PM
AF - Advisor
Re: Q Octane
I already answered that question. The O2 sensor has to have some mileage on it, and the cat wont last long.
Kevin Jewer
Old 10-31-2004, 01:30 AM
mustange kiler mustange kiler is offline
Re: Q Octane
up the street from my house they sell 114 oct
