Old 10-22-2004, 12:57 AM
korndogg's Avatar
korndogg korndogg is offline
Send a message via AIM to korndogg Send a message via MSN to korndogg Send a message via Yahoo to korndogg
Who here knows...
how to take out a stock stereo on a 99 silverado.....never did one on this new of a truck before. i would appreciate it or if you know of a site that could tell me. thanks!
1968 Camaro 327
1999 Silverado 1500 Z71 LT
{o,o}
|)__)
O RLY?
http://www.cardomain.com/id/korndogg002
Old 10-22-2004, 06:36 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Re: Who here knows...
Okie. First, set your parking brake, then turn the key on, not start the truck, just turn it on, and put the gear selector into "1". Tilt the steering wheel all the way down and then start popping off the dash trim. All it does is pop off, so you'll just kinda have to find the easiest place to start it. Mine usually starts at the vent. After removing this piece, the radio should just come out by pressing down on the 2 plastic clips on either side of the radio, and pulling it towards you. You then unhook the wiring harness and the antenna wire and your good to go!
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 10-22-2004, 12:11 PM
korndogg's Avatar
why the hell would i have to turn the truck to on and put it in 1?
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 10-22-2004, 12:16 PM
gtmud gtmud is offline
Maybe to give you the clearance you need to remove your dash
Old 10-22-2004, 12:38 PM
korndogg's Avatar
thats what i thought...wasnt sure though
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 10-22-2004, 10:54 PM
vnotaro vnotaro is offline
Re: Re: Who here knows...
You have to turn the ingition on to unlock the shift lever to get it out of the way. Makes it easier to remove the trim around the dash.
Old 10-23-2004, 12:43 AM
korndogg's Avatar
ok i got a prob here.....i cant get my amp to work for some odd reason...but now my radio and my gauges wont turn on....what the hell did i do?
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 10-23-2004, 02:02 AM
korndogg's Avatar
ok i figured out it was a fuse......for you guys with systems.....what wire do i hook up the remote wire comming from my amp to?
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 10-23-2004, 08:57 AM
Pewter'01SS's Avatar
Pewter'01SS Pewter'01SS is offline
Well...This probably isn't what most people do but on mine, I ran it into a toggle switch that I mounted in the dash. I wanted to be able to turn the amp off while still listening to the radio. If my amp overheats, I just turn it off and let it cool down or if I just want the radio on quiet, there's no need to have the amp on too. Anyway...your radio should have a remote wire coming out of it.
R.I.P. Andy...It was an honor to have known you.
'01 Camaro SS - SLP Short Throw Shifter, Granatelli Air Lid, blue neon underbody kit
'92 Chevy 1/2 ton 4X4 - 350 w/ 190,000 miles and in desperate need of a rebuild.
'86 Chevy S10 - 350 w/ 400 Turbo trans, B&M Pro-Ratchet, 4.56 Posi, 350 is gone and slowly being replaced.
Old 10-23-2004, 01:32 PM
korndogg's Avatar
i heard that stock stereos dont have remote wires tho..
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 10-23-2004, 01:52 PM
airtight_python airtight_python is offline
I dont believe the stock stereos have remote wires or audio outputs. There's probably an adapter you can get to run an amp.
Old 10-23-2004, 11:59 PM
korndogg's Avatar
yes...i have the adapter for the RCA cables.....i just need to know what wire to connect the remote wire to.
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 10-24-2004, 09:21 AM
chuck16's Avatar
chuck16 chuck16 is offline
Hey Korndogg,
Does the RCA Adapter thingy fit right into the back of the stock CD player? If so where did you find such a thing?
If you can't find a remote connection on the back of the CD Player I would just attach your remote turn on wire to a 12V Lead that goes on and off with the Key.
I did that with my fog lights and it works great.
Hope the install is going ok.
Ev
2008 GMC ACADIA
SLE Edition, 7 passenger model
I AM Canadian!!
Old 10-24-2004, 06:29 PM
korndogg's Avatar
its called a Line Output Converter. got it from circuit city for 20 bucks. and yes it fits right behind it. i put it behind it and to the left...theres a big opening there. i have one in my camaro too.
which 12v wire did you use by the way??
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 10-24-2004, 11:57 PM
chuck16's Avatar
Cool thanks.
The wire that I used is a Green wire that comes out of an orange power block in the side dash fuse panel.
Open your driver side door.
Open Fuse panel door
Dead center on the bottom of it you'll see the orange block with the green wire coming out of it.
Stick a test light on there and switch your ign on and off; mine works like a treat.
Let me know if you want me to take pics for yah.
Evan
2008 GMC ACADIA
I AM Canadian!!
