Just purchased '96 4 cyl Contour for my daughter. Extremely nice car for mileage (137K), but "Check Engine" light is on.
I ran a scanner check and got P0304, Cyl 4 Misfire. Pulled plugs and regapped to 0.050" (they were at 0.070") and replaced plugs (swapped #1 and #4 plugs). and reset light. Car ran smoother and previous slight hesitation was gone. Thought problem was solved. 10 miles later, light is on again. Obtained maintenance records for car and found that the "Cyl 4 Misfire" has been a problem for past 40,000 mi. Owner replaced wires, plugs, etc. I plan to swap #1 and #4 Fuel Injector (in case #4 is too lean) to see if problem moves to %1 Cyl. Also plan to look for intake leaks around intake manifold near #4, though plug didn't look like it was running lean. Any other ideas out there? Thanks, Bob |
you may want to add some electrical grease to the spark plug so you know it has a good connection with the wire.
![]() "The CEG Nazi" www.contour.org 1996 Ford Contour SE - Sold 3.0L V6 and Arizona Dyno Chip Turbo Kit 364 whp, 410 wtq @ 16 psi and only 4,700 rpms. 1999 Tropic Green SVT Contour - Bone stock and MINT |
The problem has now morphed-
The Cyl 4 Misfire has stopped coding, and now I am getting a PO401 and P0420, which are: 1st Bank Cat Efficiency (I assume this is the downstream O2 Sensor) and EGR Flow Insufficient Can/should the EGR valve be cleaned (and is it worth it) or should it just be replaced? |
