Old 10-22-2004, 12:42 AM
tardster tardster is offline
Question duel alternators
how would I go about putting a second alternator on my car, I have a good alt from the 88 and would like to put it in the 82 so I can hook the system, and other acc's to it instead of the original alt.
Old 10-22-2004, 12:49 AM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
I don't think you can hook up your system directly to an alt. I think there needs to be a battery for eletrical system stability. Voltage regulators can't react fast enough to step up the voltage for when something like a subwoofer hits. You would have a temp. current drop and that is what fries eletrical shit. How much of a system are you putting in that beast
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 10-22-2004, 12:53 AM
'97SLVRBullet's Avatar
'97SLVRBullet '97SLVRBullet is offline
Send a message via AIM to '97SLVRBullet
Re: duel alternators
If you want good advice on a system and great prices, get ahold of TWDZ28...he is a distributer and damn good installer.
97 Z28
C.A.I. Edelbrock shorties,all free mods,Borla's,MSD,LT4 timingchain, 1.6r/r,LT4 cam, NGK,p&p heads,ported maf ,52mmTB adj fuelpressure reg.,373's,pcm tune by pcmforless, all poly bushings,spohn t/a, s/t brace, etc. What I don't have..no egr no air pump and no cats
Well dip me in chocolate and
throw me to the lesbians!!!!!
Old 10-22-2004, 01:50 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
the route most go with a high output audio system is a second battery with a higher output alternator, power capacitors can be uses as well.
Old 10-22-2004, 01:59 AM
well what im wondering now is if i can hook up the second alt to a second battery is that possible. I have a second battery so if i put the alt on and run the red wire from the back of the alt to the battery and ground the battery would that work and what would i do with the 2 wires that come of the top? there both the 63 amp stock alts, they both have the one red wire off the back and the two plug wire on the top.
Old 10-22-2004, 02:04 AM
Dude just run two batteries in parallel on one alternator, it should work fne, if not go with the capacitor.
97 Z28
Old 10-22-2004, 10:13 AM
so positive to positive and neg to neg correct and will that help any with the draw on it?
Old 10-22-2004, 06:27 PM
lckycharm713's Avatar
lckycharm713 lckycharm713 is offline
Re: Re: duel alternators
well said, i was going to say the same. the capacitors hold and store power. get a good battery, capacitors, and better altenator if needed. no need for 2 alts. i never heard of them b4 in my life. you can tell if you need more power when you see you radio(head unit) pulse to the beat of the music. it dims bright and low, then you are dranning your battery and alot of juice for the alt
2000 Mustang - just a V6 with lots of good looks
1974 Camaro - 350 4bolt main .30 over, turbo 350 trans w/ shift kit.
1999 F-150 Lariat 4x4 5.4L
"Only babies suck bottles (NOS)"
Old 10-23-2004, 01:20 AM
yes my lights flicker, so if i put another battery in it will it stop that and all I have to do is run the poss to the poss and neg to neg? Is there something between the 2 batteries or should I ground them to differant spots? Sorry I've never done anything like this and dont want to mess anything up.
Old 10-23-2004, 01:56 AM
4onFloor's Avatar
4onFloor 4onFloor is offline
cant you get a higher output alternator? i think charging 2 batteries with the stock alt. might overwork it a little bit
Old 10-23-2004, 02:46 AM
Now it wont, it is in parallel, not series so it's still just a 12volt system.
97 Z28
Old 10-23-2004, 10:35 AM
mike123 mike123 is offline
get a battery isolator
Old 10-23-2004, 02:41 PM
you also have to make sure your head unit can handle the power. thats also why it flickers. they sell betteries that are ment for audio systems. i really dont know anything about them, i still have the stock berry from 00 in my car. those capacitor hold the power, they are what you need. i know rockford makes them. they look like a coffie can almost. go to like best buy and see what they say. or just another car audio place. ask questions like your interested, you donthave to buy anything
Old 10-23-2004, 03:07 PM
So how do I run them in parallel?
Old 10-23-2004, 05:41 PM
Bus the batteries together w/ the same large gauge wire as they already use, and tie them into the leads from the car.
97 Z28
