Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-21-2004, 11:57 PM
rshottie1998 rshottie1998 is offline
Send a message via AIM to rshottie1998
Smokin Eclipse
ok...i have a huge problem with my car smoking!...whenever i go somewhere...especially if i drive about 60 or 70...my car smokes from under the engine. i thought it was my belts, but i changed then and it still does it... what could it be?
Brandi
Old 10-22-2004, 07:23 AM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: Smokin Eclipse
Is your temp gauge going above the normal position?
For Sale 98 Eclipse GS, 5 spd
Old 10-22-2004, 09:34 AM
riff22 riff22 is offline
Re: Smokin Eclipse
does it smell like burnt oil?? could be leaking out the valve cover on to the manifold
Old 10-22-2004, 09:48 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Smokin Eclipse
What color is the smoke? Can you tell where it is coming from?
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 10-22-2004, 11:34 PM
Re: Smokin Eclipse
my temp is normal...my car isnt overheating at all....the smoke is white, and i did think that it was the oil burning onto something bc i just recently broke off two valve cover bolts into the head...but when i replaced them, the smoke was still there....i noticed that it was coming from the manifold in the space between the manifold and the head on my 98 eclipse...the smoke gets worse when i accelerate, and is bad when i idle...thats pretty much all i know..
Brandi
Old 11-15-2004, 01:49 PM
sol brother sol brother is offline
Re: Smokin Eclipse
i had the exact same problem yesterday. i took my friend out for a ride to show him why he should sell his civic , and it went retarded. the first time i boosted up my car made a deep gurgley sound like i had an exhaust leak, so i immediatly came off the gas. i drove around for like 10 minutes, and tried boosting again. the noise had stopped. when i pulled into my driveway my car was smoking off of the exhaust manifold. i just got the head rebuild, and a new head gasket, so i dont think anything is hitting the manifold from the head.
