| Off-Topic Talk about anything other than cars. |
OK...i drive the hell out of my car...when i get on the road and ive been driving for about 20 minutes or so....at high AND low speeds...whenever i park my car and turn it off smoke comes out from under the hood. i thought it was my belts, so i replaced them...obviously i was wrong...it is white smoke and very noticeable, but my car is not overheating. What could it be?
Brandi |
Re: Smokin Eclipse
Maybe you have a small hole in your radiator and when you turn you car the water burns off and the steam comes out of the hole. I dont know for sure but its a guess =D. Hope this helps
Re: Smokin Eclipse
![]() Bottles are for babies - Real men get blown!!! Car pics 97 eclipse rs - Sold 99 eclipse gs - Blown Motor 97 eclipse gs-t - For Sale 98-99 eclipse gs-x - ![]() - Looking for one
Re: Smokin Eclipse
when i looked at it today i noticed that the smoke was coming from my manifold....when i accelerate it gets much worse...do i just need a tune up, or is something going wrong?
Brandi |
Re: Smokin Eclipse
it will probaly be a coolant leak dripping onto another hot element such as your exhaust manifold or exhaust pipe. coolant can leak from so many places its hard to pinpoint, but if you read 2 posts up, that person had a similar problem, so id check there first. then check all your coolant lines for leaks.
Tim 1990 Talon AWD 2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink, PTE SCM5031
Re: Smokin Eclipse
Get a coolant pressure tester and see if you can find the leak.
For Sale 98 Eclipse GS, 5 spd |
Re: Smokin Eclipse
What colour is the smoke?
Re: Re: Smokin Eclipse
![]() ![]() ![]() ![]() 98 Eclipse gst-race ready 95 Eclipse gst-stock 92 Eclipse GST-parts car 91 Talon tsi RWD 87 Conquest-our new baby |
Re: Smokin Eclipse
I would say that sounds like something dripping onto the mani for sure, as other have suggested. A single drop of oil or coolant being fried can smell and look like your engine just blew.
I got a 95 mitsubishi eclipse gs-t and mine does the same thing but the problem was mine is that the dip stick was messed up and i was gettin on the headers and the head that was where all of my smoke was coming from~!~ Check that out if it isn't that check your head and c if there is any leaks comin from there~!~
Re: Smokin Eclipse
-1997 Eclipse Spyder GST |Stock| -1990 Eclipse GSX |ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar| |
Re: Smokin Eclipse
well i will check the coolant and everything but when i usually check my coolant, it is kinda low.. and i i have oil leak...im thinking that it is my oil pan gasket, but im not sure..however had the car before my looks like they didnt know how to drive a low car. the oil pan has a big dent in it like someone bottomed out...do u think i should get a new one...if so, about how much do they run..and where could i get it from
Brandi |
