Go Back   Automotive Forums Car Chat > Ford > Contour
Old 10-21-2004, 11:44 PM
greezypaws greezypaws is offline
Contour Hot and Jerky
1999 Contour 4 cyl. This car has 75,000 miles of trouble free service, but now is acting up. During light to moderate acceleration, the pulling force of the acceleration is unsteady. There is a smooth surge of power, then a smooth decline of power over and over untill crusing speed is attained. This tugging effect is not bumpy but is somewhat intense. Also, just 2 days ago, the air conditioner stopped cooling, and the car has begun to overheat quickly after any load. Driving very easy will allow the temp to decline slightly. The radiator fan is on constantly. Roll down the windows, turn the heater on full hot, and the temp drops drasticly to normal.
Could this be a restricted exhaust, the catalytic converter maybe? How about a restricted or failed thermostat? Is there a reason the AC would stop cooling? Has anyone seen this before?
Old 10-22-2004, 04:58 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Contour Hot and Jerky
sound's like the a/c compressor died.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 10-22-2004, 10:19 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
which engine do you have?
Old 10-22-2004, 02:49 PM
pre98zetec's Avatar
says hes got the 4 cylinder.
-Josh-
Old 10-22-2004, 10:29 PM
The 4 cyl engine for a '99 contour SE is an overhead twin cam. This one has VCT markings on the cover.
Old 11-04-2004, 09:43 PM
Problems solved!!
The overheating was caused simply by failure of the thermostat to open. Easy.
The cause of the engine surge however, I discovered by accident. While “struggling” with the radiator drain plug I had to get under the car to get to it. While under, I looked around and saw the PCV line had collapsed in a way that was causing an intermittent air flow condition. The hose had re-formed itself into a permanent half-collapsed shape. Otherwise I might have never found the problem.
Old 05-09-2005, 07:03 PM
bertm bertm is offline
where is the radiator drain located on the 1996 2.0L?
