Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 10-21-2004, 09:46 PM
jdi226 jdi226 is offline
Send a message via AIM to jdi226
Ticking noise when i turn
On my new 98' sunfire, sometimes when i turn there is a clicking noise? What is this?
Old 10-22-2004, 01:53 AM
hotbug1776's Avatar
hotbug1776 hotbug1776 is offline
Re: Ticking noise when i turn
CV's are going out most likely, determine which side by sound and do this...
jack up the car with it in gear.
grab the wheel you suspect the noise coming from.
move it back and forth (like it's spinning) and if there's a lot of play then it's the CV.
While there, place your hands on the top and bottom of the wheel and give it a push/pull motion, pull on the bottom while pushing on the top and the opposite.
if there is a bit of play there as well, you need new bearings as well. Half shafts are the way to go, just take out the old axle, and pop in a new one, no fuss no muss. if you need to replace the half shaft let me know, I've done quite a few sets now and can just about describe how to do it by memory.
Old 10-22-2004, 02:09 PM
Robbie1's Avatar
Robbie1 Robbie1 is offline
I heard a ticking noise on my 98.
Turned out I had a bearing that self destructed in my tranny.
if you can do the check on a hoist, that is the best thing.
Current : 2005 Dodge SRT-4
Last: 1998 Sunfire GT
"Speed costs money.....how fast do you want to go?"
Old 10-27-2004, 09:43 PM
W Colin W Colin is offline
The ticking noise could well be the CV joints. Had this trouble on my 1982 Ciera. GM wanted over $300 to replace them. went to a local garage and they removed the offending CV joint cleaned it up removing some dirt in there replaced the boot which was split and cahrged my $20 A small tick remained for as long as I had the car but this was soon forgotten and did not affect the performance of the joint in any way. Now I have a rather loud noise when I go to full left lock. This appears to be another boot this time in the left McPherson suspension. The bottom of the boot has ridden up and catches the spring at full lock. My mechanic assures me that this will not impact the shock and I have now cut the offending piece off. Any Comments?
Colin
Old 11-15-2004, 05:58 PM
Turns out it was the front brakes!
