when i'm driving the front end feel like i'm going though small speed bump up shifting, rough down shifting also when slowing down . hard
I think this the start of a tran problem. I have 34,000 and change the fuild one.I bought it new live in fl. can some give me info:or advice
Re: SEL 2000 tran.and front end
Have you checked the fluid level recently? Try to check it using the steps in the owner's manual (ATF warmed up, in park run through all gears, check it while engine running etc.). Also double check the receipt if someone else changed your fluid and make sure it was MerconV and not just plain Mercon or a Multi-Use ATF fluid.
1997 Pathfinder XE Air Lift Air Bags, Warn Hubs 2000 Windstar SEL |
