| Off-Topic Talk about anything other than cars. |
awd ecu in a fwd and its sputtering
I have a 1990 eagle talon tsi fwd, 5spd and i had to replace my ecu but the only one i had was an awd, 5spd ecu so i used it it started and since it is a newer ecu i switched the two wires i belive its wires #6 and #14 its the Idle position switch and the Air flow sensor active filter reset and it runs good but for some reason i have to pull the wires coming of the ics motor tight or the engine will stall on sputter and loss a lot of power should i just replace my ics motor? please leave any suggestions
Thanks Bryan |
Re: awd ecu in a fwd and its sputtering
I can't help you with your question, but it would be beneficial if you were to use some punctuation. Your post is difficult to understand and may prevent some people from being able to help. Good luck!
![]() 1997 Spyder GS-T 5-Speed EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads |
ive always heard that you cant swap ecu part numbers. try putting in the right ecu. search ebay i got a remanufactered one for 100 bucks
-1stGenRocks- 95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's plans: bastard 20g, water/meth injection NO FMIC |
There should be no difference in the ECUs unless its auto to manual. For 1g that makes a difference (injector size). I'm assuming you used a non 90 ECU or you wouldnt have had to swap those wires. At any rate, if the only problem is with the ISC wiring, none of this may even matter
Find out whats up with that first. May not be the ISC itself, could be the harness side. Check out the connections for corrosion, loose pins, etc.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
