Go Back   Automotive Forums Car Chat > Dodge > General Discussion
Old 10-21-2004, 02:17 PM
LXDSMXL's Avatar
LXDSMXL LXDSMXL is offline
Send a message via ICQ to LXDSMXL Send a message via AIM to LXDSMXL Send a message via Yahoo to LXDSMXL
Dodge Lancer
How much can you boost a dodge Lancer turbo 1988 without harming anything? and how much is it boosting now (stock)
Old 10-21-2004, 10:18 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Well, that depends. Does it have a Turbo I or a Turbo II?
Old 10-22-2004, 03:55 PM
LXDSMXL's Avatar
Hey Polygon I have no idea what turbo it has (sorry) its my friends car heres all the info he gave me:
1987 DODGE LANCER hatchback 4dr ENGINE: 2.2L efi turbo ohc
I have not looked under his car's hood but, even if I did I wouldn't know where the turbo is located and what kind it is. I know I could located if I took a look at it but, how would I know which type it is? We are both newbies to turbos, can you please explain whats the diff. between a turbo I and a Turbo II ?? Thank you
Old 10-22-2004, 07:50 PM
Polygon's Avatar
The Red Baron
Well, chances are you have the Turbo I. You can tell if you have a Turbo II or a Turbo I by looking next to the overflow reservoir attached to the radiator. If there is something that looks like another small radiator then that is the stock intercooler and you would have a Turbo II. If not, then you have a Turbo I. The differences are mainly that the Turbo I does not have an intercooler and it uses a Mitsubishi TE04H turbo @ around 5-7 PSI. The Turbo II has an intercooler and uses a Garrett T03 Turbo @ around 11-14 PSI. There are a lot of other differences but those are the main ones.
As for how much boost you can run, not enough to hurt the engine, I would venture to say 14 PSI at the most with a stock intercooler and some Turbo II injectors. After that the small TE04H just runs out of steam.
Old 10-26-2004, 03:22 PM
rwood13 rwood13 is offline
Re: Dodge Lancer
check out thedodgegarage.com, lot of good info about Chrysler turbos
