Go Back   Automotive Forums .com Car Chat > GMC > Jimmy
Old 10-21-2004, 01:53 PM   #1
troubles789
93 jimmy egr w 4.3 - wasnt egr, cpi?
I have read about all the problems with the egr valve and the cpi on this site. I am having problems of rough idle and missing at idle. Take off is sluggish with the miss. There is no engine warning lights on at this time. Highway speeds not bad and passing is fine. I was wondering about the egr first, I was going to take it off and clean it for carbon. What I am wondering is, has anyone just blocked off the egr with the gasket and metal plate, like we used to in the 80's? Just leaving the egr off. If so how did it run without the darn egr. I want to know cause i am thinking of trying this.
troubles789 is offline   Reply With Quote
Old 10-23-2004, 07:26 AM   #2
troubles789
Re: 93 jimmy egr w 4.3
Ok the egr cleaning didnt fix it, wasnt all that bad. Still have missing at idle and miss at takeoff and overdrive gear on highway. How do i check the cpi? I see 2 torx bolts on vortec cover. Then what?
Old 10-23-2004, 03:58 PM   #3
BlazerLT
AF -Advisor
BlazerLT's Avatar
Was there a pintle blocking one of the holes in the valve?
BlazerLT is offline   Reply With Quote
Old 10-25-2004, 04:22 PM   #4
troubles789
I dont know what a pintle is. I seen the 2 bigger holes on the egr with one having the plunger that went in and out. Where do I look for this and what does it do? It look like the gasket covered any smaller holes on the intake. Thanks.
Old 10-25-2004, 06:55 PM   #5
BlazerLT
AF -Advisor
BlazerLT's Avatar
Pintle=plunger
Have you removed the EGR valve yet?
Old 10-25-2004, 08:09 PM   #6
troubles789
Yep took it off and cleaned it. Not much carbon was built up. The pintle=plunger was sticking, so I soaked it and worked it till it was working freely. Put back on and the problem was still there. How do I check the cpi under the vortec top for leaks?
Old 10-25-2004, 08:11 PM   #7
troubles789
Yes it was stuck in one of the holes when I took it off. Just to answer your other question, I missed to tell you on.
Old 10-25-2004, 08:29 PM   #8
BlazerLT
AF -Advisor
BlazerLT's Avatar
Go in the blazer forum and do a search for cpi injector.
Old 10-25-2004, 09:00 PM   #9
troubles789
Thanks, For help.
Old 10-27-2004, 07:27 PM   #10
troubles789
BlazerLT I pulled the vortec top and then the center flapper that fits into the center of the top of the intake. Using a flashlight I could see a goldish tinge on the lower intake on the passanger side back only. Last back cyc side only. What do you think? cpi reg leak or what?
Old 10-27-2004, 07:50 PM   #11
BlazerLT
AF -Advisor
BlazerLT's Avatar
More than likely.
If there is no leaks it should be really dirty and grimey.
Old 10-29-2004, 01:09 PM   #12
JackDaniels386
dude, you dont want to block the egr valve, its supposed to be used to cool, and will run even worse if you block it off. Theres this thing that Tomco sells like a screen thing for it. look it up www.tomco-inc.com
JackDaniels386 is offline   Reply With Quote
Old 10-29-2004, 03:04 PM   #13
BlazerLT
AF -Advisor
BlazerLT's Avatar
You also do not want to use the screen.
Blocking the Carbon inside your engine is poor thinking.
You want to get the carbon out, not trap it in there.
Old 10-30-2004, 10:13 AM   #14
JackDaniels386
the carbon just gets burned off or broken down in there, even without the Tomco Klean screen you get a bunch of carbon stuck in there. It just burns it off. I've had mine for about a year and its been running awesome. I do take the thing out every once and a while and clean the screen. But if you dont want to do that, the GM dealers have a thing now where they reprogram some stuff in the computer, they call it an "EGR Fix" for it thats supposed to help make it better, but I dont know much about it.
Old 10-30-2004, 03:06 PM   #15
BlazerLT
AF -Advisor
BlazerLT's Avatar
The EGR cycle fix is all you need.
It just opens up the EGR pintle all the way sometimes to clear any chunks of carbon.
1995 Factory Blazer Service Manual for sale, PM if interested.
