Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 10-21-2004, 12:48 PM
knowlegeable1 knowlegeable1 is offline
Question 20'' rims...
Hi, im new here, and i searched but found nothing. I seen some 20''s on a malibu around here, and i just picked up a set for dirt cheap. the problem is, They rub oh so slighty on the spring support in the front. Its just slight rubbage but its rubs, so thats a nono. Does anyone know if this can be cut or filed so they wont rub? Thanks for any help.
Old 10-21-2004, 05:07 PM
ViperJ's Avatar
ViperJ ViperJ is offline
Send a message via MSN to ViperJ
Re: 20'' rims...
I would check out cardomain.com because I know alot of those guys have 20"s, you could check out their suspension. I bet a malibu looks hella tight on 20"s right. You might have to get an air suspension kit to raise the Malibu but I really am not sure enough to give you an acurate answer.
White 07 STI, Bone stock for now
Old 10-22-2004, 09:40 AM
takuel takuel is offline
Send a message via Yahoo to takuel
What the problem is with your 20" wheels is that the offset is wrong for the suspension the Malibu's have. You probably needed a wheel with a negative offset. For a possible quick fix, without replacing your suspension, check out the following links, or search for "wheel adapter" or "wheel spacer".
http://www.wheeladapter.com/wheel_ad...el_spacers.asp
http://www.1010tires.com/adapters.asp
Old 10-23-2004, 06:20 PM
yeah, thanks for the info. Ill look into the spacer thing.
