Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 10-21-2004, 11:55 AM
10sec-Hopeful 10sec-Hopeful is offline
Best Engine for 93 Accord EX
I am going to be getting an Accord EX in due time, and one of the first things I want to do is a swap. I was thinking an H22A would be perfect out of a 93 Prelude VTEC, and I found a decent price ($2,500 w/out installation).
Is there anything better I should shoot for? My long-term goal being 250-300 whp. I've pretty much got all the parts I want figured out, but would there be a better engine I should use? (Like if you heard that H22As break down a lot or something)
My 5-year plan is going to cost around $15,000-$20,000 without a turbo kit, (I plan to go all motor for awhile) and it is going to be showroom quality.
Any help is much appreciated.
Old 10-21-2004, 12:38 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: Best Engine for 93 Accord EX
H22a is the best swap for the accord. 250-300 whp is goin to be really hard to get that kind of number in the N/A class.
Old 10-21-2004, 01:34 PM
Really? Well, 300 definitely will be difficult, but will 250 be that hard?
I eventually plan to put like a T3/T4 on there with one of those beautiful FMICs, and I know I can break 300 easy with all that.
I mean, an H22a is like a 190-200 HP block right? Exhaust, underdrive pulley, new cams, intake, headers, and thats raising the hp fairly nicely. That is without a few other minor mods. But that should put me fairly high correct?
If there is anything else you can think of that I should do to the N/A block, let me know. I'm still a newbie, but I need to learn to get out of that stage.
One of my friends suggested an H22A4....but I didn't even think those were out / existed. He said its like a 220 HP plant...but I don't know.
Thanks for the help!
Old 10-21-2004, 10:14 PM
mellowboy's Avatar
The h22 your friend is talking about is the TYPE S motor. Not worth it. It just has higher compression and better cams. It needs alot of work just to see the 250 whp range. Go to www.importbuilders.com and you can get an idea from them. When you go turbo...its basically unlimited. You can reach 350 whp like nothing...with proper set up and tuning of course.
Old 10-21-2004, 10:24 PM
Redrunner Redrunner is offline
Send a message via AIM to Redrunner
Hey I need help Can I put a f22a6 head on a f22b2 Block is the wiring the same what should I look out for
1999 Honda Civic DX 1.6l I4 (Stock)
Track Best : 17.010 at 80.822 0.070 r/t (THIS IS WITHOUT N2O THIS IS MY STOCK TIME)
MODs:
Real Cold Air Intake (the one that sucks air from under car)
Compucar NOS hybrid wet fogger system (55 shot)
Old 10-22-2004, 12:00 PM
Thanks man! You've been tons of help.
Old 10-22-2004, 12:06 PM
mellowboy's Avatar
No prob
Old 10-22-2004, 12:28 PM
94accordVTEC 94accordVTEC is offline
Send a message via AIM to 94accordVTEC
Re: Re: Best Engine for 93 Accord EX
I answered this already on the other thread but
a6 and b2 are your head codes, b22 is your block code...same block so the head should fit...no the wiring is likely not the same you may even need the ecu from the one with the a6 head...but your only gaining 10hp and 3ft-lbs on torque so is there really a point in doing this?
