Go Back   Automotive Forums Car Chat > Mazda > B-Series/Bravo/Bounty/Drifter
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version.
Old 10-21-2004, 11:35 AM
mshaggy mshaggy is offline
Question Valve Guide And Seal Replacement
I have 2 engines a 1987 2L and a 1990 2.2L. The 87 2L is in my 90 B2200. Does the head have to be removed to replace the valve guides and seals, or are the heads interchangeable?
Old 11-28-2004, 03:02 AM
bigbiz bigbiz is offline
Send a message via Yahoo to bigbiz
Re: Valve Guide And Seal Replacement
They are interchangeable. The 2.0 head has adjustable rockers and the 2.2 has hydraulic lifters. Basically the same. As 4 the guides & seals I'm sure u have to take the head off even though I've never done it.
Old 11-30-2004, 06:21 PM
tj101 tj101 is offline
Re: Valve replacement
I dont believe you need remove the head to replace guide and seals. Use compressed air so valve doesn't drop in. I have not done the procedure on a mazda however. Perhaps someone will chime in with more skills than me.
Old 11-30-2004, 07:19 PM
89B2200 89B2200 is offline
Send a message via AIM to 89B2200
Yes the heads are interchangeable.
Which one needs a valve guide and seal job?
If you are just changing the valve seals, you do not have to remove the head from the block. But you have to remove the rockers to get to the seals. To remove the rockers, you have to pull out the timing belt and the camshaft pulley. Then you can pull out the intake and exhaust valve seals one at a time using a valve compressor to remove the valve springs and keepers. To keep the valve from dropping inside the combustion chamber, you have to apply compressed air through the spark plug hole to keep the cylinder pressurized. Since the rockers are already out, you can clean the hydraulic lash adjusters on the 90 2.2L before you put it back to make sure they will keep the oil and stay pressurized for quiet valve operation.
Are you swapping engines or just the heads?
Old 11-30-2004, 07:21 PM
Oh, if you are changing the valve guides, the head needs to come off the block and sent to a machine shop.
