Old 02-19-2002, 11:13 AM
Quetzolcotl's Avatar
Quetzolcotl Quetzolcotl is offline
how to recondition a 240k mi engine?
we just got a '95 integra gs-r for my girlfriend that has 240,000 miles on it. it doesnt burn oil or have anything wrong with it that i can tell. its gotten all its recomended maitenence at specified times and everything.
should i do anything to it to make sure it lasts longer? would new valve springs or piston rings or something like that help? suggestions?
"I don't want to sound like a queer or nothin', but I think unicorns kick ass." -Trey Parker from Orgasmo
Be like Ike.
Old 02-19-2002, 03:34 PM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
if it's not burning oil or running poorly, then what is there to recondition?
if it works, fucking with it will only break it.
Old 02-19-2002, 04:14 PM
spy54's Avatar
spy54 spy54 is offline
Send a message via AIM to spy54
Z-MAX! ask a stupid question....
AF Teen Crew
Purehonda.com - may she rest in peace
1996 Chevy C1500, Flowmaster Exhaust, Tinted Windows, 2 Kicker 10" L7 Subs, Eclipse 5v headunit, Alpine V12 Amp
DJM 4/6 drop kit being sold
Full Throttle 9.5 inch lift being installed
1989 CRX si "silver mist"---SOLD---.....Stripped and Wrecked in Compton
corbeau forza 2 seats, DC short shifter, Powerslot slotter rotors, AEM brake pads, Bfgoodridge Stainless steel brake lines, Greddy MX exhaust, AEM Cold Air Intake, Konig Rated-R rims, Kamikazi header
Make an Offer [email protected]
Old 02-20-2002, 12:54 AM
MARKUSIUDIUS MARKUSIUDIUS is offline
Alotta miles son
Shes been working for this long so I wouldnt spend a thing on it. Sure you could spend some cash on pistons a rings etc but if it broke a rod or crank whats the point. Only spend money on the old girl when its needed and when it packs it in, it would be better to by a fresher reco with less miles then to spend money on yours.
Keep on keeping on:flash:
1994 2.2lt Jap import Vtec, Blown with a 1GGZE charger 300Hp or 220+kw
Malpassi Reg, 500 injector, Unichip piggyback management system, Top gun leads, Map controller, Vtec controller, Custom FM Cooler, Custom fast flow exhaust and weight reduced (2640pds)
Old 02-20-2002, 06:43 PM
ludicrs ludicrs is offline
Send a message via AIM to ludicrs
preventive maintenance!!!
at 240k miles you never know it may run like it is for another 100k or it may die tommorrow. i would spend the money and not worry.
timing belt, water pump, all other belts and hoses, plugs/wires, cap and rotor, fuel/air/oil filters. that should do it, i wouldn't worry about the rings if its not smoking.
Old 02-21-2002, 12:50 AM
Deprived
posted ludicrs
preventive maintenance!!! at 240k miles you never know it may run like it is for another 100k or it may die tommorrow. i would spend the money and not worry. timing belt, water pump, all other belts and hoses, plugs/wires, cap and rotor, fuel/air/oil filters. that should do it, i wouldn't worry about the rings if its not smoking.
Why would you do all this if as above he has had the car regularly serviced and all theses external parts are fine such as timing belt all other belts and hoses, plugs/wires, fuel/air/oil filters. If it had been properly serviced they will be in proper working order.
Just maintain it as its schedule requires. And maybe service the oil and filter with a full synthetic every 4000 - 5000 miles.
All the best and dont worry, if she runs be happy :flash:
Old 02-22-2002, 01:53 PM
82civicwagon's Avatar
82civicwagon 82civicwagon is offline
if it aint broke dont f with it or you might breaqk something, speaking from experience i've got a 20 year old civic w/ 200,000+ and it ran fine besides a little smoke in the mornings from the valve stem seals seeping when they are cold, i tore it down to replace the seals and now its all f'ed up. i think i bent one of my auxillary valves when re installing the rocker arm cage. so it just goes to show if it works fine dont touch it!
82 civic wagon
amsoil high flow air filter
apex'i muffler
future motor swap ride
[email protected]
Member of TeaM NiGLeT iNC.
MeMBeR NiGLeT eLiTe GuaRD
more bodyroll than a 500 Lb G.A.W.A.
?WHAT YOU LIKE TO DO WITH PUNANNI?
POONSAI!
Old 02-22-2002, 03:14 PM
flylwsi flylwsi is offline
Send a message via AIM to flylwsi
hmm...
that many miles on a 95 means that they are most likely all highway miles...
have you revved it high alot? does it throw smoke? if yes, build another motor or buy one... if not leave it
if you think it is beat up, then go for a swap. i wouldnt bother to rebuild something that old, only b/c it will have worn everything... like the shape of the cyl's, the ports, everything would be pretty worn.
if you are thinking about reconditioning it (rebuilding it) dont do it and buy another motor, newer, less miles, etc...
Old 02-23-2002, 01:37 AM
Self's Avatar
Self Self is offline
Send a message via AIM to Self
Leave it be, boy
Don't worry, be happy! If something does go wrong, sell it, and buy something new!
There's no replacement for displacement...No, not even a turbo.
Old 02-23-2002, 10:57 AM
well, i think it would be best to ensure that we can get a few more years of use out of this engine, and be able to really run it if we wanted. would something work like putting in a LS block that has less miles (in case the cylinder walls have been warped) and then getting the crank reworked and get new type r pistons and rods or something? would the head need anything looked at? if we had it torn down and all cleaned and all that would it be like getting a newer engine?
we saved a coupe grand getting this car with high miles and want to ensure it will be ok for a while. and its a gsr so it begs to be driven hard. its hard not to. we dont really have the money for a new b18c engine but do have enough $ to work with the one we have.
Be like Ike.
Old 02-24-2002, 07:22 PM
Jarflow Jarflow is offline
Send a message via ICQ to Jarflow Send a message via AIM to Jarflow
i garen tee er tack her up and blow her broad side
My car is like my own personal universe, shes my drug and it only takes twelve bucks to fill her up, but in my galaxy there aint no room for earth, so im leaving it cause i can feel the oil pressure building up, turning over thee ignition of my solar system, check the gauges, push in the tape, put my foot on the brake, shift exsistance, light my ciggarette and take it state to state until i crash into my fate
Old 03-12-2002, 01:23 PM
3y30wnj00 3y30wnj00 is offline
Send a message via AIM to 3y30wnj00
if the engine dies and everything else is working fine try and find someplace that just sells the B18C1 block and not the entire swap kit, that should save you a buncha money.
Old 03-12-2002, 05:50 PM
would it most likely be the block that will mess up? with the cylinder walls warping? does the b18c not have a closed deck?
Be like Ike.
Old 03-12-2002, 05:55 PM
i dunno what would happen to the block on a high mile engine, i was just going on what flylwsi said "... like the shape of the cyl's, the ports, everything would be pretty worn"
Old 03-19-2002, 09:30 AM
sparq's Avatar
sparq sparq is offline
AF Premium User
Send a message via AIM to sparq
If the motor doesnt smoke and doesnt knock... what are you worried about? :o
AF's Official Asshole
RIP AUNIE
Headlight Reconditioning Information for Beginners American Pride Exterior | Bodykits | Lighting | Aerodynamics 0 11-02-2010 05:13 PM
How much is a engine and gearbox perry1234 Car Buying Q&A 0 05-07-2009 09:51 PM
how to import engines and chassis 00_impreza_GC8 Street Racing 1 12-11-2002 07:00 AM
How to clean engine??? G20RIDER Engine 11 09-09-2001 08:33 PM
