Old 10-21-2004, 09:03 AM
thebuilder thebuilder is offline
A/C Help
Sorry about the duplicate posting. Posted in the wrong forum earlier.
Installed a new A/C compressor, dryer, and expansion value. Took it down to the local Tuffy shop to have them evacuate and fill. Everything well great. As I was driving the next morning, the A/C stop working. I got out to look and the a/c clutch was no longer engaged. I checked the charge on the a/c low side and it has about 40-50 psi. I looked through all the fuses and started pushing on all the cable connections to the a/c. When I started pressing and pulling on the connctor to the hi-low pressure switch, the clutch engaged. I left the car sitting in park for about 15 minutes and a/c was still running. I then took it out for a drive and before I could get 200 yards from the house, it stopped again. I went back through and could not get it going again. I jumped the a/c clutch to the battery and it will engage so I don't think it is the clutch. I am not getting any power to the cable that power the a/c clutch. I also pulled the connector off the hi-low pressure switch and jumped a wire across the two leads (suggested by Tuffy) and it still did not work. Does that mean the pressure switch is OK?
Any ideas?
Thanks in advance.
Honda Civic DX (1.5 L)
1995
Old 10-21-2004, 09:58 AM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Re: A/C Help
Sounds like the connector or wire is bad or loose. GL
Old 10-23-2004, 11:54 AM
lmejia20 lmejia20 is offline
After taking my car to two dealers, and three different shops, the head unit in the dash got replaced and the air worked like a charm. Sounds like everything else is functioning ok.
