Old 10-21-2004, 01:57 AM
Adhesive STP Adhesive STP is offline
gas tank size?
how many gallons of gas can the tank hold on a 88 mustang LX. I heard around 15? but my tank was on Dead E today and when i filled it up it went to 13? So if it is 15 my gas gauge is kinda off and I dont have to worry so much when i get in the red.
Old 10-21-2004, 01:27 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
When my gas light went on at a little above the E, I usually had about 2 gallons left. So that sounds alright to me. I believe its like 15.3 full capacity.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 10-21-2004, 06:37 PM
StillGoin5.0 StillGoin5.0 is offline
Send a message via AIM to StillGoin5.0
Re: gas tank size?
stang racer20 is right, i just replaced the fuel pump and tank and it was a 15.3 gallon tank..
87 5.0 5 spd T-Tops - mass air conversion 9AL, msd distributer, coil, fms 9mm wires, bbk ceramic coated long tubes, bbk h pipe, 3" flowmaster catback, 190 lph fuel pump, 24 psi injectors, 70mm cobra meter, bbk AFPR, bbk fender kit with k&n filter, 12* base timing, flex fan, 3 row aluminum radiator, 6 piece headlight kit w/ clear corners, silver ponys, stormin normin cowl hood, saleen wing, and recently a new heater core
Old 10-25-2004, 06:07 PM
gmartinez gmartinez is offline
Question Re: gas tank size?
will it be the same for a 1986 LX
Old 10-25-2004, 08:53 PM
andrewespo's Avatar
andrewespo andrewespo is offline
Re: Re: gas tank size?
1982-1993 5.0's are 15.40 gallons.
1988 Mustang 5.0 5spd/CAI,BBK 65mm TB,BBK underdrive pulleys, Flowmaster catback, E303 cam, headers, mass air conversion, Steeda tri ax shifter, 3.73 gears, Trick Flow street intake, 3g 130 Amp Alt.
Old 10-25-2004, 09:39 PM
Re: gas tank size?
it's a 1986 4 cyl LX
