leaking t-tops
does anyone know any tricks on how to fix leaky t-tops on a 89 camaro?
Re: leaking t-tops
Check your seals, if they are bad you will have to replace them. You can get some silicone lubricant to keep the rubber from drying out and that helps seal with the glass. Some people put vaseline on the rubber and that works also.
Re: leaking t-tops
you can put a nice layer of vasseline around the seals and that usually stops the leaks
Re: leaking t-tops
my driver's side leaked when i first got it. i took off the top and the a-pillar panel; in the track where the top latch goes into there was a small hole in my insulation. a little black silicone caulk, 24 hours later, no leak...
*Better power-to-weight ratio than a C6 corvette* |
