Old 10-20-2004, 07:26 PM
VividVisions VividVisions is offline
Remove 2.2 crank while in car??
is it possible to remove the crank from a 91 2.2 while the engine is still in the car?? do i gotta remove transaxle BS?? its a manual. if so are their any shortcuts or do i just start tearing everything apart?? i got everything taken apart but the only thing holding me back looks like the flywheel. any help would be appreciated
V.V.
Old 10-20-2004, 08:15 PM
Social Anxiety Guy Social Anxiety Guy is offline
Re: Remove 2.2 crank while in car??
V.V.
You 2 eh. My 91 2.2 engine siesed on me the other day, but then again i was driving with a busted connecting rod/crankshaft.
Now im left having to put in a used engine this weekend
As for your situation im not sure, but i think you can pull out the crank while still in there.
Not sure though
Old 10-20-2004, 09:12 PM
public's Avatar
public public is offline
Yes. Remove the flywheel, and yank that puppy.
Old 10-22-2004, 05:47 PM
yes?? yes to what? it can be removed without the transmission coming off or the trans does have to come off?? i am pretty sure the only way to get the flywheel off is to remove the trans and undo a bolt??
Old 10-22-2004, 06:21 PM
public's Avatar
Yes it will come out. I will see if I can scan you some photos/mechanical drawings of how it is done. As I recall you can get flywheel seperated from the torque converter without removing the tranny. You can then get a wrench in there to get the flywheel off.
