Go Back   Automotive Forums Car Chat > Buick > Century
Old 10-20-2004, 06:07 PM
V12Alp V12Alp is offline
HELP check engine light!!!!
Hey everyone, here is problem with my 1997 Buick Century. Check engine light went on. There were to problems, camshaft sensor and cylinder missfires. Ok changed the sensor along with the spark plugs and ignition wires. Same problem the day after, check engine light came on againg-says missfire in the first cylinder, car seems to work fine. Need help to figure out what's going on. Changed fuel filter too.
Old 10-20-2004, 06:28 PM
public's Avatar
public public is offline
Re: HELP check engine light!!!!
You say the car is running fine now? If this is the case try some fuel injection cleaner.These cars have probles with fuel injectors plugging up. Good Luck.
Old 10-20-2004, 06:34 PM
I still have check engine light on but doesn't seem like it's loosing power
Old 10-20-2004, 08:20 PM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
No, we've had a lot of problems with these at the shop, assuming it's the newer Century, a lot of them come from the factory with bad injectors, we had one with a misfire right off the transport, just get it replaced. I would say 98 and newer have this problem.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 10-20-2004, 09:14 PM
public's Avatar
Ditto, My 98 lives on STP fuel injection cleaner about every other month.
Old 10-20-2004, 09:36 PM
Thanks a lot for your information, by the way how many injectors should I change, only one or?
Old 10-20-2004, 11:13 PM
-Josh-'s Avatar
I would just change the one that's faulty for now, they are very expensive.
AF User Guidelines
Old 10-21-2004, 06:25 PM
Thanks a lot, actually Lucas cleaner helped, so it was an injector just like you guys said, after I put the fluid in check engine disappeared after few minutes. Thanks a lot.
Old 10-21-2004, 07:35 PM
public's Avatar
Glad we could be of some help.
