Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 10-20-2004, 06:07 PM
jonmarc1 jonmarc1 is offline
Lightbulb Jetta GLS Window Problems
I Have a 1997 Jetta GLS That About a week age the Back Driver Window went down.My wife picked me up I pressed the buttons It didn't go up.About 5 minutes later the window went up on it's own.Fast Forward a couple of days late all 4 windows went down they will go up when you use the Key on the Door lock.Sometimes they will stay up for 1 hour sometimes 5 minutes also the alarm & door locks quit working.I had a mechanic look at it we took the wireing harness loose on the back driver window they will stay up.On the test CPU the test code 46-35 wont let you in the code to let you reset the codes.If there is any help out there I really Need your Input on what to do.
Thanks,
jonmarc phillips
Old 10-21-2004, 02:47 PM
boschmann boschmann is offline
Re: Jetta GLS Window Problems
The best thing it could be is a broken or shorting wire where the harness goes from the body to the door at the hinges. Pull back the rubber boot at both the back & driver's door & look for trouble. Worst case is a door module problem.
Old 10-21-2004, 06:21 PM
Boschmann,
Thanks For the help.I see you are from Asheville,I'm Orig from Old Fort.Ret Navy Now in Texas
