Old 10-20-2004, 05:55 PM
91flaredhb 91flaredhb is offline
NEED SOME HELP (wierd stuff happening when i put the petal down)
OK here is the deal... I have got a 91 civic hb that come with the extremely unattractive DPFI,... BUT WAIT!!! i had a local shop do the multi point swap on it with a jdm si manifold and 91 SI computer . Every since the swap was completed...
1.) If i hold the idle aroud 4000 or so it is really unsteady, and rough...
2.) Every once in a while, if I rev the engine up and let it rev down,and do this over and over (where it kind of sounds like a rev limiter, "to get you on the same page as i am" ) It will backfire through the intake manifold : not cool
3.) Last major thing is if i run on the interstate (it is a 4 speed) and tap 3rd to the limit and shift to 4th, it almost feels like it runs out of gas for a split second right as i shift and step back on the gas. Basically it almost dies for a split-second...
WHAT THE HECK IS GOING ON???ANY SUGGESTIONS OR COMMENTS???
Old 10-20-2004, 05:57 PM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
Re: NEED SOME HELP (wierd stuff happening when i put the petal down)
for the back-firing, replace the PCV valve on the manifold. I picked mine just the other week at Autozone for $2.88, It's supposed to stop backfiring. Also, the timing might be off.
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
Old 10-21-2004, 08:02 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Sounds almost like they might have mixed up something with the MPFI swap. Read through this thread and try to see if maybe that's it... (something about EACV and IAT plugs looking alike and plugged in wrong)... Also, are you getting any codes?
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 10-21-2004, 09:06 AM
big bad mohawk guy's Avatar
big bad mohawk guy big bad mohawk guy is offline
timing. it was rough one mine to
1988 crx hf
cool air intake
#1 racing exhaust
sprint spings
B&M SHORT SHIFTER
gutted cat.
Old 10-21-2004, 11:25 AM
yeah it is flashing codes 1 and 15 i think or 13 what do they mean???
Old 10-21-2004, 01:19 PM
Hybrid1990crx's Avatar
code 1 is o2 sensor. code 13 is atmospheric pressure.
code 15 is ignition output signal.
Old 10-21-2004, 01:53 PM
travagliante's Avatar
travagliante travagliante is offline
Yeah problem number 3 is due to a bad o2 sensor or a disconnected one-which happened to my friends protoge.---connected it securly and it works fine!
