Old 10-20-2004, 05:44 PM
aking3000gt aking3000gt is offline
Send a message via AIM to aking3000gt Send a message via Yahoo to aking3000gt
Dumping the Clutch
what does the phrase mean "dumping the clutch"? and how do you do it?
I have an idea just would like to know for sure... and is it good for the car?
1994 3000GT VR4 Pearl Yellow
1994 3000GT Base Pearl White
Check out my Cardomain Website!!!http://www.cardomain.com/memberpage/800196
Old 10-20-2004, 05:54 PM
crazy_quick crazy_quick is offline
Re: Dumping the Clutch
Well dumping the clutch is when you drop it from high rpms. The only thing that takes a beating is your clutch so it's not good for your clutch unless you got a proformance clutch.
Old 10-20-2004, 05:59 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Its letting the clutch engage very quickly withought realy stoping at it's catch point to let it slowly engage.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 10-20-2004, 06:20 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Taking your foot off the clutch peddle as fast as possible, gennerally a high RPM to spin your tires, with AWD cars this with do 1 of 3 things.
1. Make your car stall, or very close to it.
2. Make your car take off and throw you back in the seat.
3. Break something
Old 10-20-2004, 06:28 PM
Igovert500's Avatar
blue + red light magnet
Re: Re: Dumping the Clutch
3. Break something
Aim for result #2
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 10-20-2004, 06:32 PM
Thourun's Avatar
I've been too much of a pussy to get anything but the first result, always thought I'd brake something if I let it out any higher, so I never got a good fast launch in my SL.
1995 3000GT VR-4
Old 10-20-2004, 10:50 PM
mike93vr4's Avatar
mike93vr4 mike93vr4 is offline
do not dump i am on my 3rd trany broke the t-case every time i do like kind of a dump i let it go till it start to engage and hold it till the rpm start to go up than let it out the rest of the way it worked the best for me
Old 10-21-2004, 03:23 AM
yeah, but the 6 speed transfer cases are much much stronger. However I dont not dump the clutch either, I get a better start by slipping the clutch opposed to dumping it.
Old 10-21-2004, 11:41 AM
ok wut does slipping the cluth mean?
Old 10-21-2004, 12:29 PM
Technical_Automan Technical_Automan is offline
Banned
it's the opposite of dumping, slowly letting go of the clutch...as long as your tires spin when you dump the clutch (and keep spinning) you won't hurt anything. But if you have good tires and not enough power to make them spin when you dump the clutch from say 7500 RPM's, somethings gotta give and will most likely break in doing so. If you want to do it that badly, wait till it rains or when you're on ice to practice.
Old 10-21-2004, 01:59 PM
mike93vr4's Avatar
i have a 6 speed and i still broke my t-case
Old 10-21-2004, 04:17 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
so i guess some of us have had some bad luck dumping/slipping the clutch. i dumped the clutch on some 6000rpm launches a few times racing when i first got my car. since it had pretty crappy tires, i wore them down really fast. so ya, don't dump the clutch unless you don't care about your tires and don't mind shelling out some $$$$ to get new ones.
HEY! WHOA! an epiphany! if you wanted to just have some fun, get some slicks, or any tire with a LOT of tread, then go around dumping the clutch all you want...maybe practice some burnouts (if you have the power).
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 10-21-2004, 04:55 PM
alright well how much does a t-case usually cost?
Old 10-21-2004, 08:18 PM
mike93vr4's Avatar
when i broke my 3 i hade to buy new trany to because the shaft broke of inside of it. my t-case and trany was a little over $4k but i have a 6 speed not the 5 speed that my car came with
Old 10-21-2004, 09:46 PM
Igovert500's Avatar
Don't dump the clutch often, our clutches and t-cases suck...but it is my opinion that everyone who owns a vr4 should at least experience one 5k+ dump sometime in thier life.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
