Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-20-2004, 05:43 PM
RADMANX RADMANX is offline
new squeak..
first of all.. yes i have searched through the forums but havent found a problem like mine.I have a squeaking belt somewhere in the car.. the thing is it only squeaks when i am at a complete stop, if i am revving at all there is no noise?! anyone have any idea which belt this is and what i can do to fix it.. My Mitsubishi dealership wants $90 to tighten the belts and $190 to replace all the belts.
Like i always say, "I live my life a 1/4 mile at a time, and for those 19 seconds or more, i wish i was boosted..."
2000 Honda Civic EX
Just starting...
Old 10-20-2004, 07:21 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: new squeak..
with the car running open your hood and listen for where the squeking is coming from. then turn off the car and tighten that belt up a little bit.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 10-20-2004, 09:05 PM
I showed it to my dad who knows a little about cars and he said it is most likely a bearing going out in either the alternator or the water pump. that would be a serious pain in the ass the replace the water pump. also, i went to drive to my buddies tonight and it didnt make any noise at all?!
2000 Honda Civic EX
Just starting...
Old 10-21-2004, 03:13 AM
joemathews's Avatar
joemathews joemathews is offline
Re: new squeak..
A worn or blown bearing is unlikely to make a squeak; more likely a whine. In addition, a bearing would be louder or at least as loud when revving the engine when it is under load. Improperly tensioned or stretched belts usually grap traction shortly after being put under load, especially when wet. Try playing with the adjuster bolts on the pulley mounting brackets, or have your belts replaced and re-tensioned altogether.
1996 Eagle Talon
