Old 10-20-2004, 05:23 PM
chompipe chompipe is offline
Unhappy Water puddle inside car
Hello...Yesterday was raining really hard here in the Bay area... In the afternoon when I got in my car there was a puddle of water on the passenger side front floor... The water is coming from under the dash... Help...What can cause this in addition the the heavy rain???? Thank you....1999 Pontiac Grand Prix GT.....
Old 10-20-2004, 11:57 PM
crx1989's Avatar
crx1989 crx1989 is offline
Send a message via Yahoo to crx1989
Re: Water puddle inside car
I have a 98GT that did the same thing. Water in passenger side, radio speaker wires shorted out and water dripping from over head console. Buddy with a 2001GTP has the same problem. I'm thinking a possible windshield leak. Dealership offered no answer either. They say they never heard of such a problem. Let me know if you find anything.
Old 10-21-2004, 02:01 PM
stlwagon stlwagon is offline
Check the cowling betwen the windshield and hood. There have been many complaints where it has come unsealed.
Old 10-21-2004, 05:34 PM
pcavanagh1984 pcavanagh1984 is offline
Many cars have a heater part right there that might leak water, you should check that out as well.
Old 10-21-2004, 07:06 PM
Only other problem which is well documented in various other posts is the a/c condensate drain in the passenger side firewall plugs with debris so it can't drain to the outside. But sounds like your problem is probably weather-related (unless you've seen this before after running the a/c for an extended period).
Old 10-21-2004, 09:46 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Stlwagon is right. It's the AC drain.
Old 10-24-2004, 02:46 PM
Thanks everyone... Can anyone tell me how to get to the windshield seal...Thanks again...
Old 10-24-2004, 04:23 PM
Why do you want to get to seal? Had the same trouble with mine. It's the drain.
Old 10-24-2004, 10:20 PM
crx1989's Avatar
It's a weather related problem, not an A/C drain problem.
He said it happened during a heavy rain, the exact thing
happened to me and a friend.
Old 10-25-2004, 08:52 AM
As said, same thing happened to me. ONLY when it rains. AC has to deal with all the water. When it tries to dry the air it over flows, into the passenger side of the car.
But I have been wrong before. But it is easier to clean out the drain then to reseal window.
Good luck
Old 10-25-2004, 09:06 AM
crx1989's Avatar
I think I get what your trying to say. Let me get this right. Water normally goes into the cowling (where the windshield meets the hood) and drains through the a/c drain. In this case the a/c drain is plugged up and is draining into the passenger floorboard. That would make
sense.
Old 10-25-2004, 10:40 AM
There are about 10 threads on this site, with this same trouble. I thought it was a joke till it happened to me. Thought I would have to get a pump to get the water out. Big-L sent me an email, I went out and did cleaned the drain and it never came back. If I can find thread, I will send.
Old 10-25-2004, 10:46 AM
Here's one http://www.automotiveforums.com/vbul...d.php?t=240039
Try this one.
Old 10-26-2004, 09:13 PM
troy1 troy1 is offline
AF -Advisor
Hey guys
My girl had the same thing with here Impala there was leaves blocking a drain passage on the passenger side under the cowl I think or in the fender cant remember which
Old 10-26-2004, 09:20 PM
Drain is on the firewall.
