Old 10-20-2004, 05:06 PM
PeterK PeterK is offline
'01 GT Dome light, radio, and door lock lights
The dome lights on my '01 Grand Am GT stay on after I start up the car and stay on until I drive away. As soon as I come to a stop, the lights come on again and the same thing starts over. When I normally shut the car off, the radio will stay on until I open the door. Now as soon as the car is turned off, the radio will turn off. Also, when I would lock the car with the remote, the headlights would flash and the horn would beep. Now it just locks.
I tried replacing the door lock relay with no success.
Any ideas?
Old 10-26-2004, 07:32 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: '01 GT Dome light, radio, and door lock lights
Sounds like one of the door switches is bad. They are the ones that turn on the lights when you open a door.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 10-27-2004, 11:51 PM
e2helper e2helper is offline
Right (what poncho said)
It makes a little more sense when you understand that the vehicle is designed to turn off interior lighting due to a door being opened when the vehicle is moving. That explains the first thing you mentioned
The radio staying not staying on is also an indication of same problem (vehicle always thinks a door is opened).
The last thing might have happened if you inadvertently changed the vehicle personalization feature in your vehicle and turned off remote activation verification, however I thought you could only disable the horn chirp If you have your owners manual look that up (page 2-12). http://www.mygmlink.com/pdf/go2conte...001grandam.pdf
Since you aren't complaining about key in ignition warning without driver door opened I would say the problem is not with your driver door.
